Old 03-Jul-2006, 17:21   #1
996 996 is offline
quick action throttle ?
Anyone tried one of the demon tweeks 'quick action' throttle units on their bike (or any one elses for that matter)........whats the result ?
thanks
Old 03-Jul-2006, 17:41   #2
khushy khushy is offline
khushy's Avatar
I have one on mind . . .
works a treat - easy to fit - if you have longer bars you might need some longer cables though as they are not quite long enough on mine!
It comes with 3 cams - I have the biggest one (least amount of turn) on mine - tried the others - this one works best for me.
Unlike the advice I was given by Pro-Twins the throttle feels fab - they said it would be too hard to twist - rubbish!!!
Khushy
Old 03-Jul-2006, 18:48   #3
pedro pedro is offline
pedro's Avatar
Mood: r
i tried one, found it a bitch to fit & the cable had a frey in it.no thanks
Old 03-Jul-2006, 19:39   #4
iang iang is offline
iang's Avatar
Can you use the standard throttle cables on the new twistgrip or use the new cams in the standard throttle to save having to pull the airbox apart or is it impossible for it to work ?
Old 03-Jul-2006, 19:53   #5
Just do it with a 998 throttle! £40!
Old 03-Jul-2006, 20:36   #6
996 996 is offline
Andy, do you have to faff around with new cables or can you use the standard ones when using a 998 throttle assembley?
Old 03-Jul-2006, 20:49   #7
I had a new cable made...... £15
