Old 03-Jul-2006, 18:45   #1
iang iang is offline
iang's Avatar
Ducati 749/999 Parts
Cat Free Link Pipe for old shape swinging arm models, not deep sump. semi polished. £60 delivered.
Old 03-Jul-2006, 21:54   #2
Wave Wave is offline
Wave's Avatar
I have a Termi Assy system which means i must have the Cat still intact.
My question is do i have to adjust the ECU if i fit the cat free link pipe and does it makes it sound any louder.
whats the Benifits ?
Old 03-Jul-2006, 21:58   #3
If you have the std assymetric exhaust, there are two cats.......one in the front pipe for the front cyl, and the second in the can for the rear cyl.
Old 04-Jul-2006, 06:30   #4
You had better show us a pic of the bike mate.As far as I know,all Termi assymetric systems are cat free.You should already have the cat free link pipe.Have a look at the pipe under the crankcase,....is there a bulge in the pipe?If not,then you have a cat free pipe.
The only way to make the bike louder is fit a differant can.The Termi cans are rated at 102db,...it does'nt matter whether its an assymetric or a full 57mm,...still rated at 102bd.Summat like a Racefit can or a LeoVince would make it louder.Little or no performance gain tho.
The ECU is not adjustable.
Old 05-Jul-2006, 18:48   #5
bike mad bike mad is offline
bike mad's Avatar
if you fitted the front pipe you should be cat free as one cats in the front pipe and the other is in the box,
as for the noise the more miles you do the louder it gets, it fills up the gaps in the wadding with carbon so the gas has less room to expand and more noise gets out.
