Old 10-Jul-2014, 21:05
Campo's Avatar
Campo Campo is offline
Bikes: Class B 600ss #99
Gearing question
So I was thinking of entering the snetterton round and it apparently has a long straight. This got me thinking about my gearing as I've thought in the past that any straight any longer than cadwell and I'd have to mess about with my gearing coz the bike sounds and feels like it's about to explode at the end of park straight and funnily enough also at the end of cadwell's start finish straight (even though they are different lengths)
Anyway I've never done snetterton before and can't do the test day so if snetterton has a straight any longer than cadwell I thought I better change the gearing.
I've had a look through past posts on gearing and havn't come across anyone using the same gearing as what's on my bike.
The bike is a 5 speed 94 583 ss and came with 14t front sprocket and 40t rear. I've never tried any other gearing ratio as for the tracks I've done it seems fine.
But I do have a spare 15t front sprocket and a 39t rear.
So to prevent my bike exploding down snetterton straight would anyone with a 5 speed 583 share there snetteron gearing secrets?
Old 10-Jul-2014, 21:35
milesaway's Avatar
milesaway milesaway is offline
Bikes: 900ss 600ss xr400
if yr bike is same as mine (which it sounds like it is) you could try 15/40 as you have it already or 15/41
Old 10-Jul-2014, 22:01
Shane depending on the actual primary drive ratio the bike would have had as standard road gearing
15/36 gearing if its a 2.28 to 1 primary (a lot taller than your 14/40 which is equal to 15/43)
and
15/41 gearing if its a 2.00 to 1 primary (not far off your 14/40 which is equal to 15/43)
Old 10-Jul-2014, 22:10
Campo's Avatar
Thanks miles.
And Kev I think my head just exploded. Your post confused me more than the wife's sudoku puzzles
Old 10-Jul-2014, 22:30
right
the very first 600SS came with a 2.28 to 1 primary drive and had a 15T front sprocket and a 36T rear sprocket
During 1994 they changed the primary drive to a 2 to 1 ratio a change of 14%
as such the final drive gearing need changing to compensate so the rear sprocket was also altered by 14%
Knowing which one you have is the key
Old 10-Jul-2014, 22:34
Campo's Avatar
Ok Kev thanks
Is there any way of telling which primary drive ratio I have?
Old 10-Jul-2014, 22:41
well you could remove the clutch cover and count the teeth on the primary drive
the other way of telling is the output shaft for the front sprocket is shorter on the 2.28 to 1 engines, maybe Mark Hamilton or Andy Claridge could let you know what their early engines measure
Old 10-Jul-2014, 23:07
Campo's Avatar
Ok kev thanks
  #9
Old 11-Jul-2014, 06:44
I think Kev means remove the Sprocket cover, not the Clutch cover
  #10
Old 11-Jul-2014, 10:27
No I don't Chris as the only way to be certain is to remove the clutch cover you can then count the teeth on both the primary gear and the clutch basket 32/73 respectively for the 2.28 to 1 and 31/62 for the 2 to 1 ratio
The output shaft is a good guide but there is nothing to stop someone having changed the primary gearing on a previous occasion
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:50.
