Old 12-Jul-2006, 09:30   #1
Jasper Jasper is offline
Jasper's Avatar
Suspension eccentric
For those of you with adjustable ride heights with an eccentric at the top of the rear shock linkage,could you please tell me in what position you have yours in?Mine is currently at the 4 O'clock position.I 've been told anywhere betwen 5-8 is best.I have tried this,but at slow speeds(ie round town),the bike feels really "tippy".I know there is now more weight over the front.Is this a trade off for the quicker steering?
Cheers.
Old 12-Jul-2006, 10:28   #2
851neil 851neil is offline
Mood: need a bike...
hmmm, can't remember where I set mine - will check tonight and let you know.
Old 12-Jul-2006, 13:21   #3
paynep's Avatar
Mood: Wet wet wet
Mine's in a box in the loft waiting to be fitted- but was on the middle setting when it arrived.
HTH
Old 12-Jul-2006, 13:42   #4
jgriff jgriff is offline
jgriff's Avatar
Mine is rotated 2 notches anti clockwise from your picture. Works fine.
Griff
Old 12-Jul-2006, 13:51   #5
Jasper's Avatar
Paynep,what do you call "middle"?.
Old 12-Jul-2006, 13:51   #6
Jasper's Avatar
Jgriff,that is the standard setting -3 o'clock
Old 12-Jul-2006, 13:59   #7
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
As this discussion is about suspension settings can I ask what everybody uses to pump up the underseat reservoir for the rear shock? I was using air but was told to use nitrogen. I'd love to know which is correct. ( Sorry to hijack the thread )
Old 12-Jul-2006, 14:15   #8
you should use nitrogen (so I've been told) - a lot of people use oxy from an air line, but Nitrogen is much more stable under extremes of temperature and you'll find that your rear shock doesn't go off as quickly !
Old 12-Jul-2006, 23:27   #9
jgriff's Avatar
Nitrogen is the prefered gas, many advantages to it. All aircraft use nitrogen for struts, accumulators etc, for tyres as well. You just have to have a supply.
Straight oxygen should not be used, and never ever ever mixed with oil. It combusts.
Thanks Jasper, thought it might have been as I've never touched it.
Griff
Old 13-Jul-2006, 11:39   #10
philthy's Avatar
Thanks for that guys. I think I know where I can get it sorted now that I know what to use.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:52.
