Old 21-Jul-2006, 18:00   #1
doogalman's Avatar
Post Spider in my clutch!!!
What are the symptons of the spider spring loosing its tension. It's not snapped but i have a feeling it may need replacing. Thoughts please...
Old 21-Jul-2006, 19:21   #2
Felix Felix is offline
Presumably, you're talking about a slipper clutch. If the spider spring looses tension, you'd get less engine braking as the clutch would start to slip more easily under closed throttle. It shouldn't really affect forward motion, although that depends on the brand of clutch you're using to some extent.
If you do a search, I posted the measurements for checking the spider spring a while back. You easily measure the height of the spring when layed on a flat surface.
Old 21-Jul-2006, 19:57   #3
doogalman's Avatar
cheers felix. Will look it up.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:03.
