Old 21-Jul-2006, 22:06   #1
rsvpiper rsvpiper is offline
rsvpiper's Avatar
Question 996 race bike/help?
Hi All,
After many years of 'i want!' well err... i have now got my mits on a late model 996 to race in the sound of thunder
Well it's a typical race/track bike bit rough around the edge's but basicly sound. now i've had new belts fitted the only prob is the lack of idiot lights, got rev/temp and as yet have been unable to find the light connection to the speedo( only had a quick looksee) I have the speedo complete showing about 600 mile.
I don't rearly fancy running it in anger without an oil light and need it sorted before the end of this month so i can run it at Cadwell
Any input welcome
Piper#61
Old 21-Jul-2006, 22:54   #2
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
RSV if you take off the nose cone and look behind the rev counter pod, you will see where each light bulb is located. They are a push fit. Pull each one out one at a time, check the bulb and replace it before removing another. This will save you the hasle of having to sort out which bulb goes where.
If that fails, check the connection on the pressure switch just in front of the clutch housing. Failing that it might need a new pressure switch?
Old 22-Jul-2006, 11:28   #3
rsvpiper's Avatar
996 race bike/help?
Hi Jon,
a poor explination i feel,..the speedo's off so no idiot lights but dont see connection for speedo lights ect back to the main loom. as i wanted to run a nutral/oil light for piece of mind, I'll have another rummage about tonight
Old 22-Jul-2006, 16:38   #4
Jon Jon is offline
Jon's Avatar
Piper I see your from Nottingham? It might be worth giving Nelly of Cornerspeed a call, I'm sure he will be able to sort you out.
http://www.cornerspeed.co.uk/
Old 22-Jul-2006, 18:27   #5
Mood: Come on spring!!!
The oil light is inside the rev counter????
Old 22-Jul-2006, 23:06   #6
rsvpiper's Avatar
996 race bike/help
Keh!!
Cheers Jon will pop over on monday
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:04.
