Old 05-Aug-2014, 22:38   #1
Fudoshin Fudoshin is offline
Cool Speedo drive spacer
I've often seen people mention removing the speedo drive from the wheel of their track/race bike and put in a spacer instead - can anyone advise on where I can get a spacer or if its usually improvised, what have people used before?
its on a 2000 748bp if that matters. Assuming I can obtain said spacer do I also remove the dust seal and wheel mounted plate that mates with the speedo drive?
Cheers!
JP
Old 06-Aug-2014, 01:23   #2
Jasper Jasper is offline
Jasper's Avatar
The dust seal remains and you remove the drive. I just made one up on the lathe. Not sure what others do?
Old 06-Aug-2014, 10:42   #3
A good tip for making spacers is to buy a bearing with the same internal and width measurements that you want - the outer size is not important - and then cut off the outer race to leave you with just the inner race, and a perfect spacer! You can pick bearings up for a couple of quid each, and you know they're made of the right material too.
I did this when removing the speedo drive on my 748 and fitting a TransLogic dash.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:54.
