Old 20-Sep-2003, 14:51   #1
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
Re: Ducati Performance hugger
Dealer said as standard the hugger is only held on by two bolts on the left so it flaps about a bit.
He recommnded a small hole and screw into the swingarm on the right side.
Anyone else had this done?
A bit poor when it is an expensive original accsseory.
Lee1980
Old 20-Sep-2003, 15:09   #2
DJ Tera DJ Tera is offline
Yep tecmoto did the same when i bought one off them, not much you can do if there isnt anywhere to bolt it to on the right, not a flaw in the hugger more like a flaw in the bike!
Old 20-Sep-2003, 15:13   #3
Totto Totto is offline
There is a section on Ducati .com describing how its OK to drill & tap a small hole in the swingarm to allow the hugger to fit better !
Old 20-Sep-2003, 20:19   #4
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
my swinging arm has been drilled and tapped even with a bolt on it the hugger still flaps about like a mad thing
Old 20-Sep-2003, 21:48   #5
psychlist's Avatar
Mood: Lucky? For some, maybe!
Originally posted by Nigel C
.....even with a bolt on it the hugger still flaps about like a mad thing
But Nigel, in true blackadder tradition, surely you mean "It flaps around like a mad flappy thing"!?
Old 21-Sep-2003, 01:04   #6
Bikes: Xdaivel
Lee1980's Avatar
Thanks for replies guys
Another question answered thanks to the message board. I'm sure there will be more when I get the bike.
Lee1980
Old 21-Sep-2003, 04:14   #7
scooter996 scooter996 is offline
GO to the local hardware store and buy some 3 m or any type of DOUBLE stick or 2 sided sticky tape and apply it against the swingarm and then apply heat and then fit hugger. Works perfectly for me and does NOT flap in the wind.
Old 22-Sep-2003, 09:38   #8
paulk paulk is offline
As per previous thread - Apart from aesthetics - another good reason to fit a shock guard and seperate chain guard!
Old 22-Sep-2003, 13:36   #9
rcgbob44's Avatar
I have a DP hugger and its been drilled and fitted to the swing arm. Mine does not flap like a very flappy thing! (at all)
Old 22-Sep-2003, 13:51   #10
My hugger isn't DP and it's fitted at the two mounting points and doesn't flap either
I guess it's down to design of the hugger and the amount (layers) of carbon used along with the resin. More carbon/resin will mean more regidity to stop it flapping.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:41.
