Old 26-Jul-2006, 18:47   #1
gh999 gh999 is offline
gh999's Avatar
Mood: god must be italian !
poor running
start up ok , went about 2 mile on way to petrol station and the bike seemed like it was runnin out of fuel ... coughing and spluttering . so put fuel in but problem is still there. and if reved at standstill it cuts out . any ideas where to look 1st ?
Old 26-Jul-2006, 18:51   #2
khushy khushy is offline
khushy's Avatar
coils?
maybe you should also search for coil probs here?
Khushy
Old 26-Jul-2006, 18:57   #3
gh999's Avatar
thanks mate , will give me a starting point. but from previous bikes thought coils just packed in .... end of story! as the bike has only done 1600 miles thought it could be a blocked filter or pump relay prob
Old 26-Jul-2006, 19:10   #4
khushy's Avatar
hmmmmm - thats a strange one - presumably its still under Warranty - take it back - they will stick it on their machine!
Khushy
Old 26-Jul-2006, 19:49   #5
sheppardson sheppardson is offline
999 out of fuel
I had the same sort of problem. Check the electric plug under the seat/ tank that connects fuel sender and auto fuel off unit. The clip had broken on mine and was coming loose. I put a tie around it. They get worn when the tank is taken off for servicing etc.
Old 26-Jul-2006, 22:03   #6
gh999's Avatar
thanks will try that also . just annoying that you get all suited up ready for a cool down run out and this happens ! got full spark there , it seems like a fuelling problem as i can smell petrol from out of the exhaust.
Old 27-Jul-2006, 19:17   #7
IainMac IainMac is offline
IainMac's Avatar
Mood: I've bought a 900SL!
After my 600 mile service the fuel pipe was getting crushed on to the rear cylinder head nuts. Check that its routed around the nuts not over them. This lead to fuel starvation on mine, noticable as a flat spots on accelleration. Though if you can smell fuel it sounds like its not firing or too rich. is the choke cable routing ok (not on permanently)
Old 27-Jul-2006, 22:09   #8
gh999's Avatar
Angry 2 nights in garage !
had tank off ... checked pump and filter . wd 40'd every block connector i could find . still there ! as i've not used the bike for couple of months ... could fuel have gummed up a bit and blocked injectors ? will get some injector cleaner tommorrow
Old 27-Jul-2006, 22:36   #9
djb djb is offline
djb's Avatar
presumably plugs okay?
throttle balance?
I'll shut up now....
D
Old 28-Jul-2006, 15:23   #10
Brian_999s Brian_999s is offline
Mood: Brused and Battered
I have the same problem with mine last week it just started missing a beat every now and then now i cant even get it to the end of the road, I have tryed the coils and there both ok tested with me mates coils and it still does it. Also it you watch the engine management light comes on then goes off every now and then.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:57.
