Old 28-Jul-2006, 11:37   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Apple Airport help required
Soory to be so far off DSC topic but I have a dead airport and wondered if anyone knew how to open then up for an investidation?
Brute force or subtlety?
Rgds, rob
Old 28-Jul-2006, 11:46   #2
Give Gizmo a shout either here or on:
http://www.ducati-upnorth.com
Michael seems to be a bit of an Apple Wiz
Frank
Old 28-Jul-2006, 12:32   #3
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Well, i can do the networking side but have never took one apart...
think there are 3 torx screws on the underside which should split it, might be worth a chat to Derek on upnorth, he's the electrical wiz and also uses a mac.
have you checked its not the power supply before opening it up??
there are a few different versions of the base station and knowing Apple each will have its own way of opening.
Old 28-Jul-2006, 13:05   #4
Rob B's Avatar
We are talking totally dead here. No light at all. It's the remote airport wireless unit that hangs in a wall, 3 pin plug socket.
Rgds, Rob
Old 28-Jul-2006, 13:10   #5
Ah, thats an Airport express, haven't got one here at work but have at home, will take a look tonight...
Old 28-Jul-2006, 14:20   #6
Rob B's Avatar
Many thanks. I have a feeling that it's a two halves snapped together jobbie.
Rgds, Rob
Old 28-Jul-2006, 14:38   #7
Sorted, it is in 2 halves but difficult to split
about half way down this link http://www.hardmac.com/news/2006-06-21/ has info you may find useful on opening it and replacing the fuse which sounds like it may be the problem,
http://www.vonwentzel.net/ABS/Dissec...ess/index.html shows the internals
Old 28-Jul-2006, 14:50   #8
Rob B's Avatar
Ugh, it looks like mine will have suffered the same sort of terminal failure as many others due to Apples' dodgy component selection. Ah well, shell out £89 for a new one I guess!
Gizmo, Many thanks mate. Supurb, although non Duke, tech support.
Rgds, Rob
Old 28-Jul-2006, 15:04   #9
hmm, Apples selection of parts is linked to what consumers wil pay and the current trend is our expectation of more for cheaper sounds very similar to a certain motorbike maker who occasionally suffer component failures I often wonder how i ended with Apple and Ducati as my 2 favourite brands
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:30.
