Old 28-Jul-2006, 19:48   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Adjusting headlight for MOT
Does anyone have a link to the data that I can use to set up the headlight aim in advance of my MOT?
I used to have the distance back from a surface and the max beam height for that surface but I can't find it now.
TIA,
Rob
Old 28-Jul-2006, 19:57   #2
Rob B's Avatar
'Sokay, I've just found it all in the Haynes book of lies.
Old 28-Jul-2006, 21:31   #3
WT-Frank WT-Frank is offline
Interested Spectator
Moderator
WT-Frank's Avatar
Hi Rob,
mine was still well out (high and not enough left).
If its anything like the SS adjustment - I put two nuts on the end of each horizontal adjuster and tightened them against each other, now - with a 10mm spanner I could adjust the left/right while at the MOT station easily - which is exactly what I had to do.
Cheers - Frank (iconic944ss in stealth mode)
Old 28-Jul-2006, 21:41   #4
ps - the plastic surround is very fragile
Old 28-Jul-2006, 22:10   #5
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Beam setting
(fig. 39.1)
When checking the beam setting, put the motorcycle
upright. Tyres should be inflated at the correct pressure
and one person should be sitting astride the motorcycle,
keeping it at right angles to its longitudinal axis. Place the
motorcycle opposite a wall or a screen, 10 meters apart
from it, then draw a horizontal line dictated by headlamp
center and a vertical one in line with the longitudinal axis
of motorcycle.
If possible, perform this check in dim light.
Switch on the low beam. The height of the light spot
(measured at the upper limit between dark and lighted-up
area) should not exceed 9/10
th of the height from ground
of headlamp center.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:18.
