Old 30-Jul-2006, 22:22   #1
gimpboy450 gimpboy450 is offline
gimpboy450's Avatar
Mood: crank it and bank it
Red face Diesel
Okay, went to BP today and never again. Went to fill up and went straight for the BP ultimate which i thought would be good for the engine what i didnt realise is they use the same name for both there diesel and unleaded how stupid!
Anyway didnt start the engine or turn the bike on and got it trailered home. Anyone know the best way to empty tank without stripping the bike down?? I noticed 2 pipes coming down from the fuel pump or tank can i just take one of these off and put a hose on to the metal end then suck out??
Old 30-Jul-2006, 22:31   #2
Andydesperado Andydesperado is offline
Bikes: 916
Andydesperado's Avatar
Mood: The start of a new era, great days ahead.
Hi, can only offer marginal help. have taken the tank off my 916 before, the two pipes i have are quick release so with only minor tinkering you should be able to get the tank off and then tip most of the fuelout. A manual will help after that or other people replying. could use the old pipe and suck techique though. Andy
Old 30-Jul-2006, 22:59   #3
Bionicle Bionicle is offline
Bionicle's Avatar
If i am right, (could be wrong) diesel should float on petrol so i would op for syphoning the tank if you were not totaly dry then you should not get any in your fuel pump
Old 30-Jul-2006, 23:02   #4
gimpboy450's Avatar
Red light came on and did about 5 miles before putting £10 of the diesel!
Old 31-Jul-2006, 00:05   #5
take the tank off its simple, then tip out the fuel..and wash it it again with petrol.
I take it its a 749/999?
Old 31-Jul-2006, 00:12   #6
sorry to hear of your troubles - similar post here with some interesting points:
http://80.243.187.66/showthread.php?t=7626
Andyb - hopefully you can change your 'mood' now
Cheers - Frank
Old 31-Jul-2006, 01:28   #7
Did the same about 2 weeks ago, I got as far as putting the nozzle in the tank before thinking that nozzel looks big in the tank hole..Whoooooaaaa dont squeze the lever. Close thing
Old 31-Jul-2006, 07:17   #8
Agreed!
The tank lifts off with the seat unit.They are bolted together with a 17mm bolt.Its easier to lift the rear and unbolt the seat first.This will give you better access for removing the fuel pipes and the multipin plug for the electrics.Dont forget about the breather pipes at the front of the tank near the ign switch.
Old 31-Jul-2006, 12:54   #9
gimpboy450's Avatar
Okay will do thanks guys..
Old 31-Jul-2006, 13:49   #10
Bionicle's Avatar
dont forget to grease your O rings on the plug in connectors before putting them back or you may trap and ****** the O rings
