Old 02-Aug-2006, 15:43   #1
Zimbo Zimbo is offline
Zimbo's Avatar
Mood: fair to middling
Question Rear brake caliper
Does anyone know if the rear caliper off a 748/9x6 will fit a carb Supersport ? (not underslung).
Old 02-Aug-2006, 17:33   #2
I'm pretty sure they're identical; will check tonight.
Old 02-Aug-2006, 17:39   #3
Seems likely they will - here is some info from the www.pdq1.com website:
Goldline Rear - 20.5161.42 - £51.71 per caliper
Mounting Type: Lug 84mm
Body Type : 2 piece cast aluminium
Piston Type: 2x32mm aluminium
Inc Brake Pads: Yes, 107.2686.41
Typical fitments - Ducati pre 2001 plus many other Italian models.
Goldline Rear - 20.6950.51 - £73.80 per caliper
Inc Brake Pads: Yes, 107.6949.10
Typical fitments - Aprilia 2000 on also modern Ducati.
Old 04-Aug-2006, 08:59   #4
Zimbo's Avatar
OK, thanks chaps. I had a bit of rattle coming from the caliper area when I pushed the bike to and fro but now realise it's not the pads rattling around excessively (the hole on my caliper is enlarged so I use a split pin, which means the pads are looser). The rattling was a sprocket carrier pin inside the wheel hub - it had sheared off. New thread...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:01.
