Old 05-Aug-2006, 19:30   #1
Fastfasulli Fastfasulli is offline
Clutchy things
I replaced my clutch master cylinder today and did all the bleeding thing as suggested in the haynes manual but somehow it don't seem right now.
I replaced it with a direct OE cyclinder from another monster. The replacement came with this blue rubber washer with a pointed bit on one edge where the cylinder fits to the hose - but the existing cyclinder did not have one of these so I did not use it andanyway I couldn't see how it would fit on anyway.
Having done all the fitting and bleeding the lever seems quite easy to pull in and there doesn't seem to be any bite point if that makes sense.
Also the screw adjuster has a blob of some sort of glue on it that seems to have been placed there on purpose. Very strange I thought!
Now I havn't really done anything like this before so my question is really does it sound like I have done something majorly wrong. If someone has a few simple steps that i could follow to troubleshoot it would be most appreciated.
I hope that all makes sense
Many thanks
Franco
Old 05-Aug-2006, 20:36   #2
Ok been for a spin to check it out and the clutch only works only within millimeters of letting the lever out...horrible!!!
Any ideas?
Franco
Old 05-Aug-2006, 20:46   #3
Sounds like there could be still some air in the system.
The blob of resin is there for a reason,....to stop the screw being overtightened.
Old 06-Aug-2006, 10:26   #4
Thanks KeefyB. Will try again on the bleeding front but the blob of resin is actually covering the slot for the screwdriver to fit in so even if i wanted to tighten the screw I couldn't get the screwdriver in there!! Very odd.
Old 06-Aug-2006, 10:28   #5
I don't think you are meant to touch that screw. The resin is to stop it vibrating out.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:38.
