Old 08-Aug-2006, 23:22   #1
Gav748sp Gav748sp is offline
Mood: Updating The Formula!
Slipper Clutch Lubrication!
Well guys I would just appreciate some info/feedback from all of you that are using a slipper clutch.....
What kind of grease do you use to lubricate it and how often , also what have you used and how did you find it lasted?
The clutch i have is a ramp only one and I`am looking for something that won`t be flung off within 50 miles... so of a decent consistency.
Gav
Old 08-Aug-2006, 23:39   #2
Do you have the tools for taking it apart?
Old 08-Aug-2006, 23:47   #3
Felix Felix is offline
I've had very good results with MOS2 (molybdenum disulphate) grease, or what is commonly used in CV joints for cars. You want a grade that has an extended temperature range, something that has life beyond 100 deg. C. A product called "molyslip" works well. Check with your local motor factor.
Old 09-Aug-2006, 13:41   #4
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Hi Gav,
JHP us this stuff, from this place (so do I):
http://www.londontools.co.uk/
Rocol 10040 Dry Moly Paste 100g Ref: ROC10040
ROCOL ASP ANTI-SCUFFING PASTE.
ROCOL ASP Anti-Scuffing Paste is a soft paste containing a high concentration of molybdenum disulphide providing a thin dry film able to withstand highloads and temperatures of up to 450 degrees Celsius in air. It gives a dry lubrication of plain bearings, slides and gears.
Anti-seize treatment for threaded connections.
*Dry lubrication does not pick up dust or dirt.
*Gives lifetime lubrication at light loads or under heavy loads at low speed.
*Prevents seizure of threaded connections arising from high temperatures or high load.
100grm. Tube.
LondonTools Price: £24.39Including VAT at 17.5%
Spin
Old 09-Aug-2006, 14:09   #5
9rrr 9rrr is offline
Thumbs up Slipper clutch
Hi I use the same anti scuffing paste as JHP on my Bucci slipper. I just use a very small amount where the ball bearings sit and a little on the star spring (made that up, dont know the correct name for that spring).
Ive just stripped mine having done just a couple of hundred miles since I last gresed it, as Im off to the South of France this Friday on the beast. Was advised by JHP to grease it again before I went on the trip, so I have.
Dont know the real answer of when and how often. I suppose when the gear change isnt as slick.
But I am looking at doing a few thousand miles on the old girl over the next 10 days without greasing it during this time, so I will let you know.
I would be interested to know the though.
Old 09-Aug-2006, 16:34   #6
khushy khushy is offline
khushy's Avatar
is that the green stuff that looks like chewing gum?
Old 10-Aug-2006, 21:50   #7
Thanks for the opinions guys, have gone with the Rocol option for a start and will see how we go....
Andy as for tools....how hard can it be , set of mole grips and a spanner should suffice shouldn`t it?
Gav
Old 10-Aug-2006, 23:04   #8
No, you'll need a 4 pound lump hammer as well
___________^
Old 10-Aug-2006, 23:54   #9
Gizmo Gizmo is offline
Mood: is it the weekend yet??
and the 2 metre long scaffolding pipe
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:11.
