Old 24-Sep-2003, 19:51   #1
uncledunnie uncledunnie is offline
MCN 999s suspenders....
Has anyone tried out their recently published "improved" settings?
I did, mmmm......
and they don't work for me.
I fall in the "larger" of the 2 categories.....
Old 25-Sep-2003, 07:41   #2
Mood: going for a ride...
Are you meaning the settings from about 6 weeks ago ?.......Bruce Dunns settings worked well on the road but were too soft for the track , a couple of extra clicks of compression at both ends ipmroved things but would need more track time to get it right
Old 25-Sep-2003, 09:10   #3
Chris Millie Chris Millie is offline
Must have missed that copy of MCN.....poss on hols.
Could you send me the compression/rebound settings for F/R, i'll give it a try.
Millie
Old 25-Sep-2003, 11:56   #4
I will bring the article into work and post on Tuesday , am offshore till then
Old 25-Sep-2003, 17:34   #5
Hope this is ok Chris
10 st rider:
Front preload 7 turns from full in
Front compression 9 clicks out from full in
Front rebound 9 clicks out from full in
Rear preload 24mm thread above collar
Rear compression 8 clicks out from full in
Rear preload 20 clicks out from full in
14.5 st rider:
Front preload 6 turns from full in
Front compression 8 clicks out from full in
Rear preload 26mm thread above collar
Rear preload 21 clicks out from full in
I tried the 14.5 st setup but find the back end a little twitchy.
Old 26-Sep-2003, 06:12   #6
Performance Bikes are going to do a set up guide soon.
They need a 999 for the article and will set the bike up for the owner.
Call Sal on 01733 468099
Old 01-Oct-2003, 10:00   #7
thanks for the lead Keefyboy.
My names on the list - lets see what happens......
Get a new set of tyres too
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:32.
