Old 18-Aug-2006, 21:45   #1
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Brembo Radial master Cylinder Question
Just fitted one to my 748 tonight - but how do you boys and girls mount your reservoirs ??
Pictures/ideas welcome !
Nat
Old 18-Aug-2006, 22:08   #2
Race reservoir off the top yoke, quick drill and tap job
Old 18-Aug-2006, 22:12   #3
Nattyboy's Avatar
When you say race reservoir kev do you mean the brembo screw on jobber ? Will have to get myself a longer length of hose..nothings ever simple is it ??!!
Nat
Old 18-Aug-2006, 22:24   #4
What sort of bars do you have.....you could get a plug turned to interference fit in the top end with a threaded hole in its centre to mount a bracket......
Old 18-Aug-2006, 22:30   #5
Harv748 Harv748 is offline
Harv748's Avatar
Just get some slightly longer brackets made up and position them as they are normally. Also longer hose, available from JHP and new clips make the job spot on.
Below were just temporary, but you get the idea.
Old 18-Aug-2006, 22:34   #6
Bling it baby!
Old 18-Aug-2006, 22:56   #7
Felix Felix is offline
The handwriting is appauling!
Old 18-Aug-2006, 23:02   #8
With a touch of class.......
Old 18-Aug-2006, 23:15   #9
DSC Member Karl Karl is offline
Karl's Avatar
Diy...
Old 18-Aug-2006, 23:19   #10
ducv2 ducv2 is offline
I used original bracket and reservoir, bolted to one of the handlebar clamp bolts (use a longer allan bolt). You will need a longer hose to reach the reservoir
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:15.
