Old 20-Aug-2006, 22:32   #1
duc daz duc daz is offline
duc daz's Avatar
Question do i have a problem
when switching on my 999 it makes the primeing noise for about 3 seconds then stops then the display comes on and then it primes for another 2 seconds ...never noticed this before is this the norm???
Old 20-Aug-2006, 23:10   #2
Mine makes the priming noise as the display is going and the rev counter flicks all the way around............then its ready!
Old 20-Aug-2006, 23:22   #3
duc daz's Avatar
is this ok then andy
Old 20-Aug-2006, 23:27   #4
sbwells sbwells is offline
sbwells's Avatar
Mood: Bring the noise!
Yeap mines the same. The Fuel Pump should have completed priming the injectors by the time the rev counter needle has swept the face of the dial.
I've had a couple of minor problems recently when the bike when its been left for a couple of weeks.
Firstly, rev counter needle sweaps the face of the clocks and stays at max rpm (13,000) with no speedo, temp, time showing up. Bacically the cloaks are dead. Fixed by removing and re-inserting the fuse closest to the fairing on the righthand side of the headlight assembly.
Secondly, turn on the key the the cloaks work ok but the fuel pump won't prime and bike won't start. Found this when the bike wasn't quite in Neutral. Ie Neutral light is not illuminated but the bike can be wheeled around. Fixed by fiddling with the gear level untill Neutral light illuminated and turning ignition on and off a few times.
Old 21-Aug-2006, 07:37   #5
khushy khushy is offline
khushy's Avatar
If you are saying that it primes twice . . .
that is definately NOT normal!!!
Get someone to look at it.
Khushy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:55.
