Old 27-Aug-2006, 22:34   #1
sie748 sie748 is offline
Bikes: 748 sp,748 bip , 600ss dd,speed triple.
sie748's Avatar
Mood: neeeeeeed piiiiiiiiiiiiiiiiiiie
Wink side stand?
Can someone please tell me how you modify the side stand on a 748 to stop auto lifting.
Old 27-Aug-2006, 23:15   #2
Strada916 Strada916 is offline
On my 916 the side stand is help on by a long bolt and a nut. A metal plate connected to the return spring pushes against the said nut and causes the side stand to auto lift.
The nut acts as a lock nut, as you can not do the bolt up tight, or else the side stand will not move.
So what I did was remove the nut, bolt and then the side stand. Cut down the bolt so that it does not stick out proud of the inner face of the side stand.
This means that the plate on the spring does not touch on anything any more, and therefore does not auto lift.
I then put thread lock on the bolt to take the place of the lock nut.
I assume this is what everyone else does
Old 28-Aug-2006, 00:52   #3
Nelly at Cornerspeed should be able to sort you out with a modified plate that avoids the nut on the back of the stand bolt and stops the stand flicking up
The other alternative is a stainless replacement sidestand bolt from Brancatto engineering, that does away with the nut on the back and is secured with lockwire
Old 28-Aug-2006, 12:18   #4
jj250 jj250 is offline
jj250's Avatar
Talking
Coxy, before asking about the mods i would ask for the correct torque settings, that way this one might not fall off!
Also change your avatar please, that yellow hurts my eyes!!
Old 28-Aug-2006, 19:49   #5
You use the plate and nut off the later bikes with the switch on the stand. Costs about a fiver for the pair
Old 28-Aug-2006, 20:49   #6
Dibble
you charging for that advice or just giving it freely ???
Old 28-Aug-2006, 21:51   #7
Old 05-Sep-2006, 15:55   #8
sie748's Avatar
Talking
Cheers guys job sorted.And for those wishing to do the same the plate part no. is .82912602a.
Old 05-Sep-2006, 16:22   #9
multi600 multi600 is offline
multi600's Avatar
Mood: Hopefull
I would like to convert mine to auto lift, So how do I do that??
Mike
Old 05-Sep-2006, 16:26   #10
psychlist's Avatar
Mood: Lucky? For some, maybe!
Carry a pillion
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:20.
