Old 29-Aug-2006, 14:22   #1
cj2 cj2 is offline
Bikes: Multistrada 1200s DAir
Mirror fitting
Managed to have the mirror "pop off" today - i turned it downwards to drain water out and it 'pinged' off.
I can only see a single spring inside the leg but seems a bit short to be able to easily hook back onto the black mounting on the fairing. Anyone know how to do this or is there another spring somewhere on my driveway.
Thanks in anticipation
CJ2
Old 31-Aug-2006, 21:47   #2
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
nope just the one unbolt the base from the upper fairing, that'll help u get it back on
Old 31-Aug-2006, 23:30   #3
jeff st4s jeff st4s is offline
jeff st4s's Avatar
Mood: Looking for a one way ticket to the 'Ring.
As stated, unbolt, don't try to pull spring into place as you will always slip, you may want to make a little hooking device to pull the end of the spring into place on the mounting bracket.
If you really have problems I have a tool you could borrow to pull the spring into place.
Jeff
Old 31-Aug-2006, 23:35   #4
YMFB YMFB is offline
YMFB's Avatar
How do you get the painted bit off the back ?
Old 01-Sep-2006, 01:53   #5
jeff st4s's Avatar
To my knolewdge you don't, it's all pressed together, when one of mine came off, the red plastic bit cracked and I had to buy a complete mirror with stalk section already attatched.
But when I looked at the old one it looks very difficult to get a blade in between the black and the painted parts to separate them, you will probably cause more damaged to the good bits if you tried.
Maybe someone will come along with an alternative view.
Old 01-Sep-2006, 13:13   #6
cj2 cj2 is offline
Thanks all - - suprisingly easy in the end and took about 30 secs using piece of string hooked onto end of spring.
cj2
