Old 31-Aug-2006, 21:49
Douglas Douglas is offline
Removing engine mounting bolts - advice needed!
I am trying to get the engine out of the frame of my 748, following my idler wheel disaster. I have removed the two upper mounting bolts, but cant get the lower one out. That is the one that runs through the swing arm pivot.
I have removed the bolt from the RHS, and according to Mr Haynes, it shouild just pull out from the left. Well it wont! I have WD40'd, and tried tapping it from the other ent with a drift, but it is rock hard. It feels as if it is being retained, but I cant see what is stopping it.
I have tried looking at the parts list on the web, but still cant work it out.
What's the trick anyone?!
I
Old 31-Aug-2006, 21:54
keefer's Avatar
keefer keefer is offline
Unfortunately they get stuck in situ badly.
if you have the Ducati tool kit insert the spark plug tool into it upside down.
its becomes a very large allen key then put a socket over the other end and try turning it.
other than that its just a case of persistence.
maybe let the WD40 go to work over night
Old 31-Aug-2006, 22:16
Gav748sp Gav748sp is offline
Mood: Updating The Formula!
Oh if only it was that easy......
The removal of my swingarm bolt invloved all of the above , then an even bigger hammer , some screwed rod , large washers and nuts for said rod, a hacksaw blade (no hacksaw just the blade!) , and finally a large drill and 19mm drill bit!!!
Then a Ducati Technician to remove the bearings etc from the swingarm too.
Now i really hope you don`t have to go to these lengths , to say i was upset is an understatement , and all on a bike with 5000 miles.
Lesson learnt , grease the bolt , grease it again and finally chuck some more grease at it.
Gav
Old 31-Aug-2006, 23:20
Thanks for the info chaps, although it isnt all re=assuring! I forgot to mention that I can turn the bolt quite easily, it just wont come out!
Anyway I'll try again tomorrow when the WD40 may have done its stuff!
Old 01-Sep-2006, 17:01
Douglas
Yeah sorry about the negative side , but that is a possibility as my bolt also turned.
The problem is the bolt ends up welded/stuck to the two top hat bushes that go into the swingarm (from the inside of the arm pointing to the outside of the arm) and the only way out was to cut it out.
After that then there is the replacement of all bearings , bushes and the actuall bolt at £50 alone , not a good way to have to remove the arm!!
So hope you don`t have to go there.
Best of luck.
Gav
Old 02-Sep-2006, 08:10
khushy's Avatar
khushy khushy is offline
Cool I remember . . .
trying to get mine out in 2002 - it took ages and a massive hammer - in the end I had to cut the bloody thing between the frame and the back of the engine with a hacksaw - then I could knock it out fairly easily.
Keep trying - it WILL come out in the end!
Khushy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:12.
