View Poll Results: Do you have a slipper clutch?
Yes... I need one when racing! 1 4.35%
Yes... but I don't think I really need one. 3 13.04%
No... you don't need one on a DD bike. 12 52.17%
No... but I would like one. 5 21.74%
Other (Please specify) 2 8.70%
Voters: 23. You may not vote on this poll
Old 08-Sep-2006, 23:29   #1
domski's Avatar
DD - Slipper Clutches
Do you have a slipper clutch on your DESMODUE bike?
I think we have one of those APTC clutches, but thats not a 'slipper' is it??? ******ed if I notice it making a difference anyway...
The APTC clutch, developed exclusively for Ducati, makes the 620 even friendlier, safer and more comfortable. This unique system provides clutch lever pull that is amazingly light, while it also assists in reducing abrupt downshifts that can produce destabilising rear wheel chatter. The clutch, as well as the lowered seat, make this an ideal bike for women too.
Old 08-Sep-2006, 23:30   #2
andys 900ss's Avatar
NO, but I use the back tyre instead
Andy
Old 09-Sep-2006, 07:28   #3
Otei Otei is offline
Otei's Avatar
Ha, excellent. A bit of non PC Italian, greasy, dago, Guinea wop press blurb.
Should have read like this though.
"The weeemin, they are..ow do you saaiy....too leeetle and sheeet weeth the controls to ride a bike weethout asseeestance, no?"
At least it makes it clear why I could get on one and not do too badly straight away. I'm off to get me nails done and buy a new feather boa today.
Old 09-Sep-2006, 08:30   #4
Nice to see your femenin side coming out Tim, must be that nice hat you have to wear at work.
Old 09-Sep-2006, 09:13   #5
DSC Member AK AK is offline
AK's Avatar
we have the aptc slipper in our 620 which does seem to cause a problems on lauch with a judder when pulling away hard.
Both Andy and Mark noticed this.
But when I asked Andy if he wanted me to remove it, he said no, because you only pull away once in a race - but on every corner on the downshift he found you could bang it down through the gearbox without it making the back end squirm too much although he said he could still back it into a corner.
I rode it at the Cadwell TD and comparing it with the 583 found it a lot more stable when going into Park corner for example
Personally I like it, and so do my riders but we just to overcome the slippage which both Chass & I seem to have suffered with at times.
Obviously we would prefer a full slipper but only Sigma does one for the wet clutch bikes but this is out of our budget at the moment (this is not an advert for them )
Old 09-Sep-2006, 09:42   #6
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
a slipper clutch is that when my fingers slip off the lever?
Old 09-Sep-2006, 09:56   #7
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Wink
Louigi made his own from a works dry slipper clever bloke.
Old 09-Sep-2006, 10:34   #8
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Not found the need for a slipper, the bike behaves itself nicely on the downshifts.
Although there was one occassion where i went down one too many going into Paddock Hill this year and the back stepped out... dunno if a slipper would've gaurded against that, but what did prevent it happening again was just to not hit the downchange too many times again!
Old 10-Sep-2006, 22:19   #9
paynep's Avatar
Mood: Wet wet wet
I remember the days when good riders had a technique to blip the throttle on downshifts, rather than relying on ramps and balls - but then again I'm an old fart.
Anyhow, stamping down on the little lever sticking out of the left hand casing seems to work for me - but there again I have no ramps and definitely no balls....
Old 10-Sep-2006, 22:26   #10
the old man's Avatar
I have one of them there Sigma slippa clutches on my old 5 speed 620SS (aptc not an opption without going to a 6 speed cluster).
I'm old school and blip the throttle on downshifts (while applying 10/10th braking etc) but do find the slipper helps to stabilise the bike. Especially usefull in tricky situations ie., braking downhill / over bumps, while changing direction etc.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:36.
