Old 13-Sep-2006, 17:21   #1
GeoffDuc GeoffDuc is offline
Mood: Reflective
Unhappy 749S Misfire
I've got a Ducati 749S (2003) that's recently developed an intermittent
misfire.
Last run it went onto 1 cylinder for a couple of seconds then
cleared, then the same happened again. It was then fine all the way back (40 odd miles).
Started up fine this morning, after about a mile it went onto to 1
cylinder, backfiring then would chirp back onto 2 cylinders then down to 1
again. Managed to get it back virtually 1 cylinder all the way (1 mile ). Had a good look over it but nothing seems obvious.
Any advice/cure would be greatly appreciated.
Geoff
Old 13-Sep-2006, 17:24   #2
Carbon749's Avatar
Mood: I own a flame thrower
Not had any problems myself, but, have heard many many 749 and 999 owners talk about problems with coils / spark plug caps. Seems the front one is the obvious one, gets hit by all the crud from the front tyre.
Take it off, give it a good clean, loads of WD or similar and put it back.
I'm sure someone who has first hand knowledge will be along soon.
Old 13-Sep-2006, 18:13   #3
Mine are also kind of glued in with a silicone as well!...........
Old 13-Sep-2006, 19:01   #4
bike mad bike mad is offline
bike mad's Avatar
my one was the back cylinder, lot's of water and crud and thats with a rear huger,
Old 14-Sep-2006, 12:05   #5
Wylie1 Wylie1 is offline
Wylie1's Avatar
As mentioned already, it does sound like a faulty coil. You can tell which cylinder isn't firing by checking which exhaust pipe isn't getting hot.
Once you've identified the problem cylinder, remove coil & clean as suggested above. If cleaning doesn't work, I have a spare pair of coils (used but work perfectly) & would sell one of them. Let me know if you're interested.
Old 14-Sep-2006, 22:23   #6
red seb red seb is offline
red seb's Avatar
Mood: anticipation
Smile
Fault :- Water in the plug holes clean coil and plug tops (these may even be loose) spray with wd 40 and seal with silicon jobs a good un! do not buy new coils until you've done the above. Mines done it several times before I sealed them up.
Cheers Seb
Old 20-Sep-2006, 11:03   #7
Mood: Reflective
Smile Firing on all 2
Thanks for the feedback everybody.
New plug (old one was well corroded) and a good clean/spray and I'm back up and running!
Thanks again - Geoff
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:55.
