Old 16-Sep-2006, 10:48   #1
art art is offline
idle rate
Very simple question, Im a new owner of a 916. The bike idles at about 1000rpm and stalls constantly, can anyone let me know how to adjust this
Thank you
Old 16-Sep-2006, 11:24   #2
Gaz 748's Avatar
Take r/side panel off and between the injectors is a rod with a big
white plastic nut on it, adjust to suit.
748R - Less is more !
Old 16-Sep-2006, 11:32   #3
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Maybe a little more info, are you saying it stalls on take off, but tick's over ok. 1000 rpm's about right for t/o You say you are new to Dukes and V twins. The Duke can be easy to stall if you don't get the revs right to pull away,when my wife climbs on the pillion sure bet ill stall it or close to stalling a coule of times before readjusting to the extra weight (Not saying the wifes big or anything,far from it) 4D
Old 16-Sep-2006, 11:41   #4
art art is offline
it never stalls when pulling away only when idling, which is making traffic a nightmare for a beginner like me
Old 16-Sep-2006, 11:45   #5
art art is offline
what rpm would u suggest for idling. i heard 1100.
Old 16-Sep-2006, 12:12   #6
Mr.R Mr.R is offline
Mr.R's Avatar
Surely that adjusts the ballance between the throttle bodies.The idle adjuster is a slotted screw on the front TB.
Steve
Old 16-Sep-2006, 12:18   #7
Fordie's Avatar
Yes between 1000-1100.as a quick fix when you come up in traffic use the fast idle button on the throlle twist grip to increase the revs a bit. It might help till you can sort it. 4D
Old 16-Sep-2006, 12:25   #8
art art is offline
Cheers 4D, looking forward to seeing what my new purchase can do, but until i sort this out just getting out of town is painful
Old 16-Sep-2006, 12:33   #9
Fordie's Avatar
Art, You can use the throttle master screw to adjust the idle,its where the main cable attached to the throttle body but don't go to mad with . What part of the country are you from ? 4D
Old 16-Sep-2006, 12:36   #10
art art is offline
London so have to go quite a way for the open road.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:15.
