Old 16-Sep-2006, 12:16   #1
Red-Duc Red-Duc is offline
Red-Duc's Avatar
Plug gap size
Can anyone help with the plug gap setting for my SL using NGK DCR8EIX plugs
Thanks in anticipation
Old 16-Sep-2006, 13:48   #2
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
Most folks fit NKG DPR8EA-9. These are the normal version of the iridium ones you've fitted and come pre-gapped at 0.9mm (36thou), although the manual specification is 0.6mm (24thou). The igntion system is well capable of firing the bigger gap which is less susceptible to plug fouling.
Old 16-Sep-2006, 18:26   #3
Red-Duc's Avatar
cheers Derek
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:01.
