Old 16-Sep-2006, 22:09   #1
sharpo sharpo is offline
sharpo's Avatar
Mood: Big bill-money well spent
Tyre wear question?
I noticed that the front tyre looks more scrubbed than the rear over near the edges, also i'm nearer to the edges on the front than the rear.
Pirelli 120/70 and180/55.
35psi and39psi.
Could it be the front damping or preload is too hard?
cheers
Old 16-Sep-2006, 22:29   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Braking deep into corners?
Old 16-Sep-2006, 22:45   #3
sharpo's Avatar
I'm not that quick, maybe I don't know i'm doing it?
Old 17-Sep-2006, 01:04   #4
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
is the bike understeering.
sounds like it must be
as the back is pushing the front when cranked over
raise the rear or lower the front
Old 17-Sep-2006, 06:59   #5
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
I would say thats nomal,if you fit a 190 on the rear then you would see the front closer to the edge as its a 180 and has a smaller profile the front does'nt get such a hammering in the corners. Thats my experiance between the two as Ive just gone back to a 180 from a 190. 4D
Old 17-Sep-2006, 21:42   #6
sharpo's Avatar
It is a 180 so i'm not sure what you mean 4D
I have dropped the forks through the yokes, or raised the yokes up the forks if you prefer so yes the front is higher than it was when I got it, i'll change it back or lift the rear.
Is this the result of what people mean when they say "pushing the front"?
Thanks all.
Old 17-Sep-2006, 22:23   #7
Fordie's Avatar
"Pushing the front" thats when you go into a corner a bit too hot/fast and still be on the front brake ,your'e then "pushing the front" tyre to its limit of adession and a possible spill.
The 180 is the width of the rear tyre (180mm) with a 180 on the rear your front tyre will turn quicker into a corner and lean over in comparison to the width of the rear tyre thus the "Chicken" strip ( where the tyre has not been used)will be wider, but closer to the edge on the rear
With a 190 mm rear tyre because its wider you find the front is slower to turn in and will wear nearer to the edge , as you are trying to overcome the extra width of the rear . Sounds complicated you need to see it more than talk about it. Hope that makes sense 4D
Old 17-Sep-2006, 22:32   #8
ericthered40's Avatar
Mood: renegade sexy racer
All is normal if they look like this,
Old 17-Sep-2006, 22:43   #9
domski's Avatar
Originally Posted by ericthered40
Attachment 1225
Attachment 1226
Attachment 1227
Attachment 1228
They can't possibly be yours ETR
...where are the grass stains?
Old 17-Sep-2006, 22:50   #10
All my own work me old flower, chasing Ali on a 583 at Cadwell last year
Still couln't catch the **** anyone up for 2007 620 it's only slow and ezzzzzzzzzzz
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:16.
