Old 17-Sep-2006, 08:52   #1
CipiVTS CipiVTS is offline
CipiVTS's Avatar
916 Oil leak
Hi all,
I noticed a few days a ago that oil is dripping from the bottom of the engine to the exhaust pipe. I tracked the source and it's around the area where the oil cooler lines are attached to the crankcase. Are these lines known for having this problem? The strange thing is that the oil lines are clean (even the connectors), the oil is on the crankcase!
Can i replace them? Can you point to an online store from where i can buy them?
What are the parts i have to replace?
Thanks and regards
Old 17-Sep-2006, 20:27   #2
There are a couple of points were you can get a leak around there. Not common but it happens.
The two bosses that the hoses screw onto. Check they are tight. If need be, take them out, ptfe tape the threads and refit.
Check the hoses are secure on the bosses. Again, ptfe tape on the threads helps.
Also check it's not coming from higher up. O-ring on the oil filler cap and the oil pressure sensor.
Old 18-Sep-2006, 03:42   #3
mikesps mikesps is offline
The early hose fittings quite often cracked. People would see a small leak and tighten them up which just made it crack more.
Old 18-Sep-2006, 11:03   #4
yeti yeti is offline
yeti's Avatar
Had this recently on the RS. Repalced the cheese alloy hoses with good old steel jobs and the things still leaked. Turned out to be the oil cooler in the end. Leaking between the top two galleries!
Old 18-Sep-2006, 12:16   #5
khushy khushy is offline
khushy's Avatar
I had a leak on my old bike - turned out to be a copper washer on one of the fittings - a 2 minute job and an easy fix.
I would try that first.
Khushy
Old 22-Sep-2006, 08:57   #6
CipiVTS's Avatar
I'll check the washer 1st, happen to me on a brake hose as well and it was the tiny copper thing.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:16.
