Old 18-Sep-2006, 21:44   #1
PC repairs - can anyoen help?
My Dad's PC has stopped working, it originally looked like it was a PSU prob, so I bought a replacement, but it still will not power up - I do get a small green light on the motherboard though.
It seems from what I've read that it might be the motherboard at fault, and ebay may be my best route.
Its a Emachines 2220, are there many types of motherboard that might be compatible? I'm not too concerned about getting exactly the same type, but want one that works.
Anyone got an expert opinion that I can speak with?
Tim
Old 18-Sep-2006, 21:53   #2
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
what processor and memory are you using? can you give us full machine specs from the documentation that came with it please.
Adam
Old 18-Sep-2006, 22:01   #3
Redsps Redsps is offline
Redsps's Avatar
common fault with a lot of these emachines tim, I've replaced 13 motherboards in them in the last 6 months.
They use pretty generic motherboards , not really a problem to replace it, just need to know the overall spec , or the model of the motherboard, worst case just the board layout and onboard options etc.
easy to source you one, but be carefull going down the ebay route , you can get a whole heap of probs to be honest.
drop me a line if you need one cheap.
Robin
Old 18-Sep-2006, 22:06   #4
Thanks guys - I'm looking at the motherboard now - all I can find are the following numbers on labels;
40001106-04516 (EM) 144901
TGSR41411816 AA C54560-203
And etched on the motherboard;
E210882
Does this help?
Tim
Old 18-Sep-2006, 22:27   #5
Redsps's Avatar
I suspect that this is the general spec tim for that info.
" D845GVSR Celeron 2.7Ghz "
easy replacement , best option would be to upgrade to a slighlty better board tim, but still compatible with all existing hardware. Not a prob eitherway.
Have quite a few boards in the parts rack, will check them out to see whats suitable, if you would like that is.
robin
as a double check, can you take a digi pic looking down on board, and one looking at the rear I/O panel and ports, cant have too much info.
Old 18-Sep-2006, 22:29   #6
Robin
I'd really appreciate it if you can.
Tim
Old 18-Sep-2006, 22:35   #7
Redsps's Avatar
tim the board should be this spec. "Intel® D845GVSR (Sea Breeze) Mainboard "
Processor
Support for an Intel® Pentium® 4 processor in an mPGA478 socket with a 400/533 MHz system bus
Support for an Intel® Celeron® processor in an mPGA478 socket with a 400 MHz system bus
Chipset
Intel® 845GV Chipset
Memory
Two 184-pin DDR SDRAM DIMM sockets
Support for single-sided or double-sided DIMMs (DDR 333/266/200)
Support for up to 2 GB system memory
Audio
Audio subsystem for AC '97 processing using the Realtek ALC202A codec
Video
Intel® Extreme Graphics controller
Onboard I/O Connectors
Up to six USB ports
One serial port
One parallel port
Two IDE interfaces with Ultra DMA 33 and ATA-66/100 support
One diskette drive interface
PS/2* keyboard and mouse ports
Three fan connectors
SMSC LPC47M172 LPC bus I/O controller or National Semiconductor PC87372 LPC Bus I/O controller
Onboard IDE
• N/A
Expansion Slots
Three PCI bus add-in card connectors (SMBus routed to PCI bus connector 2)
BIOS
• N/A
Onboard LAN
• N/A
IEEE 1394
• N/A
Form Factor
microATX (9.60 inches by 8.20 inches [233.69 millimeters by 208.28 millimeters])
Old 18-Sep-2006, 22:39   #8
Blimey ;
One of the small chips has "SeaBree" written on it, there are 2 DIMM slots, there is a seperate NIC mounted in a slot, can't get the heatsink off easily to check.
But sounds promising. - how much am I looking at for a replacement? any chance of a p/ex for a spare PSU?
Tim
Old 18-Sep-2006, 22:46   #9
Redsps's Avatar
these are lowend intel chipset boards tim, best option would be to upgrade to a better spec board but backwards compatible with existing hardware you allready have. From a cost point of view, its a better plan anyway, very little in it cost wise for a better spec board, and more reliable..
Only pence in it to be honest tim at this end of the market in desktop PC's.
Old 18-Sep-2006, 22:51   #10
Robin
You have a PM
Tim
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:38.
