Old 19-Sep-2006, 20:00   #1
stuart miles stuart miles is offline
stuart miles's Avatar
Mood: CHANGES LIKE THE WEATHER
Need to fit a new starter motor to 996
Hi i'm trying to fit a new starter motor to my 996 having drained all oil & water removed all the allen key bolts the casing will not move.Am I missing something.
Old 19-Sep-2006, 20:03   #2
keefer keefer is offline
keefer's Avatar
its being held in place by the power of the magnet on the fly wheel.
have you not got the Haynes manual ?
you need to make up a plate with some bolts to draw it off the crank case
Old 19-Sep-2006, 20:04   #3
keefer's Avatar
Originally Posted by Fordie
Yes there is a bolt that comes in from the other side if Im not mistaken. 4D
I think you may be mistaken
Old 19-Sep-2006, 20:10   #4
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Yes I think I am, just checking the bible 4D
Old 19-Sep-2006, 20:14   #5
keefer's Avatar
hmmm just checked what you said and I presume you are talking about the crank case cover.
you have to remove this to undo the 3 bolts holding the starter in situ
Old 19-Sep-2006, 20:22   #6
yes its the crank case cover im trying to remove
Old 19-Sep-2006, 21:20   #7
Fordie's Avatar
Yes that was what I was implying. You may need a puller to get the casing off. There is a bearing that attaches to the crankcase cover from the crankshaft and can be tight to pull of. 4D
Old 20-Sep-2006, 10:21   #8
You'll most certainly need a puller of some sorts as the magnets are pretty strong. There's also a bead of sealant holding it in place.
Have you removed the screw from behind the clutch slave cylinder? This one gets missed regularly and ends up with the cover cracking when you use a puller
Old 21-Sep-2006, 13:00   #9
loony888 loony888 is offline
Mood: sensational!!
when ready to reassemble, remember to ensure the water pump impeller lines up with the drive pin too.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:16.
