Old 20-Sep-2006, 21:55   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
Alternater nut
What is the torque setting for the alternater nut on a '00 996.
Mine has worked it's way loose
Old 20-Sep-2006, 22:02   #2
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Haynes says 186nm
Old 20-Sep-2006, 22:06   #3
crust crust is offline
Mood: :( broken
Before you do it up, check the flat washer behind it is in the correct place and not dropped down.
I had the same thing and the washer got mashed by the gears and part of it found its way onto the sump plug.
Do a search on here for more info on this problem.
Crust
Old 20-Sep-2006, 22:52   #4
keefer keefer is offline
keefer's Avatar
yep you need to strip it down to make sure it all goes back correctly
Old 21-Sep-2006, 12:05   #5
Flat washer is split.
Have been told a different figure for the torque 270nm.
Sounds quite high this one.
Old 21-Sep-2006, 12:12   #6
keefer's Avatar
270 is for the later testastreta engines
Old 21-Sep-2006, 16:50   #7
sorted
Many thanks to Nelly @ Cornerspeed, He has put me right with the settings for the nut.
Cheers.
Old 21-Sep-2006, 17:17   #8
chrisw's Avatar
What is it? May help others in the future.
Old 21-Sep-2006, 17:26   #9
210 nm.
Old 21-Sep-2006, 17:36   #10
stuart miles stuart miles is offline
stuart miles's Avatar
Mood: CHANGES LIKE THE WEATHER
Cool
thanks for the settings i'v just had the same problem with my 996 but was told to look and see if the gears had been damaged.Wicked all fine.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:26.
