Old 24-Sep-2006, 21:47   #1
Ozz Ozz is offline
Cucciolo
Bikes: 848 Evo Corse
Ozz's Avatar
Mood: Waiting for the revolution!
Monster - few questions!
Only got it last friday but a couple of questions so far (some may be answered by a Haynes manual assuming there is one):
1. The seat - it move back and forth about 2 inches. Is that normal? Had a look underneath and nothing appears to be missing.
2. Front brake. I have put it down to the wet weather ride but when braking from more than about 50mph it gave out a large squeel. The braking seemed fine and there was no judder so have ruled out warped discs...
3. The clutch currently bites too close to the bar for my preference. I assume there is an adjuster at the business end of the cable for this to change the bite position? (Have not really had a chance to look but a quick look and seemed to be a nut to move).
Old 24-Sep-2006, 21:56   #2
Scooter916's Avatar
Mood: Hmmm Conference season
HMM
1, not right
2. Strip and clean, reasemple with a bit of copper paste on rear of pads, check anti squeal shims.
3, No adjustment hydraulic. try bleeding.
Hope this helps
Glyn
Old 24-Sep-2006, 22:06   #3
Albie Albie is offline
Albie's Avatar
Seat. Is it actually located at front. It slots under a locator and then sits down at back on a pin or a latch and clicks.
Brakes. Sounds like worn pads or dust trapped or needs copperslip smeared on BACK of brake pads. My back one sounds like an old bus.
Clutch try bleeding. Overnite cable tie the clutch lever to the bar to expel air
Old 25-Sep-2006, 21:04   #4
Ozz Ozz is offline
Cucciolo
Ozz's Avatar
Seat cured! 2 to go....
Has anyone bought the ducati workshop manual online? I saw a link from Yorkie on the Monster site. 2.5 euros I think...
Old 25-Sep-2006, 21:22   #5
Albie's Avatar
Did I help. Hope so. Good luck with others.
Old 25-Sep-2006, 22:25   #6
Ozz I have a PDFs of the 2000 Monster 600 I can email you if you want, the parts manuals and the owners handbook around 4.5mb for one and 3.77mb the other
Old 25-Sep-2006, 22:26   #7
Ozz Ozz is offline
Cucciolo
Ozz's Avatar
Kev that would be brilliant! Email is ducati@phelliker.freeserve.co.uk.
Many thanks!
Old 05-Nov-2006, 21:22   #8
Ozz Ozz is offline
Cucciolo
Ozz's Avatar
Am about to do the clutch as today the bike was moving forward with clutch lever all the way in!
Also think I'll get some new front pads. Anyone recommend a make/dealer?
Old 05-Nov-2006, 22:12   #9
The clutch on my M600 has been feeling a bit iffy of late, as though the clutch hose is expanding to far or the mastercylinder isn't moving enough fluid, not quite dragging but doesn't seel like it use to.
Lots of pads around including some on Ebay.
best stick with the tried and tested Brands
Carbon Lorraines/EBCs/Ferodo/Bendix etc
Old 05-Nov-2006, 22:17   #10
http://cgi.ebay.co.uk/Ducati-EBC-FA9...QQcmdZViewItem
http://cgi.ebay.co.uk/Ducati-Brembo-...QQcmdZViewItem
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:10.
