Old 27-Sep-2006, 09:19   #1
Dougducati Dougducati is offline
Mood: Got a life and have no agenda!!
Rear Ride Height On A 583SS
Any suggestions on how to get more rear ride height on a 583SS? Is the only way to put a longer rear shock on it?
Old 27-Sep-2006, 09:25   #2
I seem to remember someone looking at an adapter of somesort but not sure of the outcome - search for posts by Kev (Skidlids) I think the easiest way is to use a longer 900ssie shock.
Frank
Old 27-Sep-2006, 09:35   #3
andys 900ss's Avatar
As Frank says Doug,
We have a 750ssie shock in and it works ideal.
Andy
Old 27-Sep-2006, 09:39   #4
Thanks chaps. Kind of knew that was going to be the answer.
Old 27-Sep-2006, 09:41   #5
phil_h phil_h is offline
phil_h's Avatar
twpd may still have one of his original 800ssie shocks for sale - I bought one of them.
Old 27-Sep-2006, 09:51   #6
Scooter916's Avatar
Mood: Hmmm Conference season
have a look at phil2`s bike
I noticed a jack up kit fitted to what appeared to be a std shock.
Glyn
Old 27-Sep-2006, 09:54   #7
psychlist's Avatar
Mood: Lucky? For some, maybe!
Smile
Louigi had a set of adapters made up about an inch long that screwed into the loop arm/tie rod, then the eyebolts screwed into them. A few that tried them said it raised it a lot tho, but you could always drop the forks thro the yokes a smidge to compensate! I asked James to weld an extra 3/4" to the end of each loop arm and that was about perfick.
Quite a bit cheaper than a new shock, but I ended up getting one for this year anyway
Old 27-Sep-2006, 10:06   #8
phil_h's Avatar
Its an SS paul, and they dont have a linkage.
Old 27-Sep-2006, 10:42   #9
ali ali is offline
ali's Avatar
Mood: Damp
Phil had an adaptor made up which seemed to work well, or you can get a longer shock. Ohlins DU235 is up to 12mm longer than std, but if you're going to spend that sort of money then I'd recommend you get one made up with a custom body length. It'll only cost about £50 more and you'll have the exact adjustment range you want.
Another alternative if you buy an ohlins, or any other with ride height adjustment, is to have a new spiggot made up for the lower end. This is what I intend to do this winter, have a few made of varying lengths and spend some time finding out which's best.
If you search back on the board you should find some post from Skids & I on shock length:
http://www.ducatisportingclub.com/sh...ighlight=du235
Cheers,
Ali
Old 27-Sep-2006, 21:53   #10
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
I have an adapter fitted, but it just feels to biased towards the front. So I whipped the Ohlins off my 996R and stuck that on It feels about right.
Or in other to put it another way. The std ss shock 325m with the adapter this increases to 365mm So by swopping the shock for the Ohlins (305mm) It works out at about 340mm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:30.
