Old 30-Sep-2006, 17:53   #1
9rrr 9rrr is offline
Different heat shield for bigger exhaust
Hi just bought 54mm Termis to replace the 50mm ones I had on. The fixing positions were the heat shield goes are in a different position than that on the 54mm Termis.
Does this mean I will have to buy a heat shield to fit and do they exist. Thought heat shield would just bolt straight on. Any ideas gents. Thankyou.
Old 30-Sep-2006, 19:05   #2
ducasa ducasa is offline
Hi, you will need the long Corse heat shield, I have a new genuine MS Productions (ie Genuine Ducati) Corse heat shield, brand new and never used, retail at £70. I'll let you have mine for £45
Will take your your other heat shield in PX if its MS Productions
Old 30-Sep-2006, 20:37   #3
final_edition's Avatar
The 50mm is the longer one, 54mm require the shorter type.
Available from Casoli, that's where I had to go.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:22.
