Old 08-Oct-2006, 20:39   #1
Chef Chef is offline
Bikes: 998S Chili trackbike,749R (corse kit), 748SPS
Chef's Avatar
Mood: Flange - it's a state of mind....
Question 998s ride height/front sag settings
Just curious I have my front sag at 27mm (std 20mm) (rear ride height 245mm - all other setting by 100% suspension - very good bloke!)-I run the std 120/70 190/50 tyres
Changing the front sag has improved the turn in but made it less stable (surprise surprise!) - anyone else tried fiddling withy the front sag?
Just curious??
Old 09-Oct-2006, 04:58   #2
rcgbob44's Avatar
I have a lot of front end sag but I put it down to a love of good food!
Things of beauty: Ducati 998s Mono: BSA DBD34: Vincent Black Shadow: Manx Norton: 1983 Laverda Jota: Matchles G50: Me!
Old 10-Oct-2006, 18:23   #3
bostrom998 bostrom998 is offline
bostrom998's Avatar
Mood: Long on Duke's...so happy
I'd be tempted, if it's quickening up turn in your after, to think about junking 190/50 and replacing with 180/55.............will do much more for you. try it when current tyre wears out?
Old 10-Oct-2006, 21:43   #4
I run the front sag on my 996 at 30mm and the rear at 10mm with the rideheight set at 245mm.
But as the forks have been reworked with different internals and fitted in adjustable offset yoke to complement the longer Mag swingarm I'm not sure how a standard bike with these settings will behave
Old 10-Oct-2006, 22:06   #5
david.hicks david.hicks is offline
david.hicks's Avatar
Oooh - look at you.
Old 12-Oct-2006, 20:53   #6
Chef's Avatar
Slidlids - sounds pretty much how my bikes set up less 3mm off the front & no mag bits!
Thinking I might try 24mm sag on the front to calm it down a bit........
Old 12-Oct-2006, 22:25   #7
dont forget its more than the mags bits, they're also longer, which makes up for head angles etc etc
Old 13-Oct-2006, 01:38   #8
Correct
Chef says his bike is less stable but I have addressed that problem in the same way as the factory race bikes did, by increasing the wheel base, altering the weight bias and altering the trail.
To an extent I have slowed down the steering but this is then compensated for by the longer bars, lighter wheels and a softly set steering damper.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:40.
