Old 10-Oct-2006, 00:51   #1
Eddieb Eddieb is offline
Mood: It's raining, Winters coming...
888 Strada Shock
Anyone got a good Strada shock laying around they don't want?
Both upper and lower bearings have gone in mine and it appears the lower bearings are not available from anywhere. My mechanic bought in a correctly sized lower bearing from the US, but it turned out not to be hardened, and hence not up to the job.
Would also consider a shock with a failed upper bearing, if the lower bearing and the rest of the shock was ok.
Eddie
Old 10-Oct-2006, 10:15   #2
Jasper Jasper is offline
Jasper's Avatar
Natty got some,not sure if they will fit though.
http://www.ducatisportingclub.com/sh...ad.php?t=35699
Old 10-Oct-2006, 11:08   #3
neil neil is offline
There's a place in Bradford called UK Suspension which fits hardened inserts with taper roller bearings for around the £30-40 mark.....I had an SS shock done there and it was a good job!
My 851 shock bottom mounts gone (same shock as 888) and I was going to do the same thing....cheaper than a new shock methinks.....
Old 10-Oct-2006, 11:21   #4
Stuart. M Stuart. M is offline
Stuart. M's Avatar
Mood: chilled
I could have a good condition showa from an 888 strada BUT it seems the SP4 ohlins i have bought dosen't fit. Mounting bushes are to big - 12mm instead of 10mm and it is 10mm shorter overal than the showa even with the ride height adjuster (should it have one?) fully extended. Also the shoulder snags on the rocker arm, when we (well Jame at Set up Engineering) tried to fit it. Can anybody help me out here - is it possible to fit an SP4 Ohlins straight on to a strada or have I been sold a pup? If there's a way then I can pass on the showa to Eddie B.
Old 10-Oct-2006, 12:38   #5
FiscusFish's Avatar
My concern about getting a second hand shock and cannabilising it for the bushes is chances are an 888 one will be a minimum of 12 years old. I've got 2 and both are worn the same way to a greater or lesser extent. Unless the one you buy is NOS or has been refurbished it'll more than likely be on the way out too....
I reckon you'd be way better taking it to an engineering shop or a suspension specialist and getting them to sort it properly. It surely couldn't be that expensive/difficult a job...?
Failing that what about getting the dealer to search for a bottom bush for a carbed Monster. They're basically the same aren't they?
Old 11-Oct-2006, 00:41   #6
Agree 100%, however New Zealand doesn't have suspension specialists or manufacturers like the UK does, and the dealers don't know squat about T8's as there are so few here. I believe only something like 5 were ever officially imported.
I have someone who can do the work, it's sourcing the right spec lower bearing that is proving difficult.
I have the word out for a M900 unit, but there aren't a huge amount of monsters in NZ either. By far the vast majority of Duke's you see around are SS's, followed by 9xx & 70's desmo models. I'd be happy if I could find a monster unit.
Old 11-Oct-2006, 01:25   #7
Mr.R Mr.R is offline
Mr.R's Avatar
Hi, Eddie i have dug out my old shock and am taking it to work to give it a wash, my wife will then take some pictures of it to send to you,then we will talk?
Steve Robins S.W. U.K
Old 11-Oct-2006, 15:11   #8
jgriff jgriff is offline
jgriff's Avatar
Here's one. http://cgi.ebay.com/ebaymotors/OHLIN...38157079QQrdZ1
Old 11-Oct-2006, 16:05   #9
aka.eric aka.eric is offline
Worth a try,
s.dorsch@t-online.de
Sells alot of Ducati parts via Ebay.Bought a couple of new Showa units from them earlier this year,may have one left?.
Old 24-Oct-2006, 21:37   #10
Hagon Shocks
Does anyone on the board know anything about the quality of Hagon shocks?
I can source these from NZ direct for a fairly good price, but I have no idea what sort of quality they are.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:30.
