Old 10-Oct-2006, 11:51   #1
Albie Albie is offline
Albie's Avatar
748 bhp
I have a 748 only base model but with Arrow 50mm full system and jhp chip and different filter. It came with a dyno test but not actually sure what BHP it really should be putting out.
It has two sheets one run shows gear changes and shows 91.73 bhp and a top speed of about 155mph. The second is a smooth incline graph with no dips showing max power 90.05 and speed of 125 before dropping down.
I thought the 748 put out about 100 a standard or is that the 748R . I thought it was comparable to the monster s4.
This is not a problem but curiosity
Old 10-Oct-2006, 16:56   #2
misterpink misterpink is offline
Bikes: multistrada, 748R/916
misterpink's Avatar
Mood: one very coool cat!
don't forget that is rear wheel italian stallions! - 10-15% lost from crank to wheel i think is normal?? a standard 748 is good at 90, i have heard of some at mid-high 80's. The R model was rated at 103 or 105 but once again this is at the crank - though have heard of some being dynoed at this sort of figure.
90hp is good especially if you use all of it in the right place.
Old 10-Oct-2006, 20:08   #3
keefer keefer is offline
keefer's Avatar
my 748SP put out 100
with 50mm full system and chip
so sounds about ok if its a bip
Old 10-Oct-2006, 22:54   #4
sie748 sie748 is offline
Bikes: 748 sp,748 bip , 600ss dd,speed triple.
sie748's Avatar
Mood: neeeeeeed piiiiiiiiiiiiiiiiiiie
Exclamation
haynes says :748 bip 98 bhp@11000
748 sps 100.3 bhp@11350
data sourced from motorcycle news road tests . So if MCN says so it must be true!!!!.
Old 10-Oct-2006, 23:12   #5
Albie's Avatar
Thumbs up
Thanks guys. I gather this would have been measured at rear wheel so that may equate to the 10% if at crank which would then be 101. Like I said it has been breathed on with system and chip. Is enough for me.
For now!!!! LOL
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:30.
