Old 10-Oct-2006, 22:09   #1
cmoss cmoss is offline
996 Rear Caliper/ Disc
Hi Guys, some info from some of you racers, is there a direct upgrade replacement rear caliper for the road 996 ? also what options on rear floating disc have seen a few on the race bikes but are these babies available to fit to the road bikes ?
Before you all say, I don't use the rear. Some people do and by choice.
Many thanks Chris.
Old 10-Oct-2006, 22:19   #2
I think AP do a rear caliper with a bigger pad area not sure if its a direct replacent though, the race Brembo ones that I have seen so far don't fit onto the standard caliper.
as for the rear floating disc, not sure how much it would actually improve the braking without being a larger diameter, only really seen them on race bikes where the weight saving is a issue
Old 11-Oct-2006, 09:41   #3
rcgbob44's Avatar
Brembo also do a rather sexy 4 pot rear caliper but it goes out the door at over 500 beer vouchers and needs a bespoke caliper mount as well.
Things of beauty: Ducati 998s Mono: BSA DBD34: Vincent Black Shadow: Manx Norton: 1983 Laverda Jota: Matchles G50: Me!
Old 11-Oct-2006, 11:15   #4
Ray Ray is offline
Ray's Avatar
Chris,
If you are just trying to improve the rear brake I just fitted some FA47 EBC pads,
They appear to be very soft and wear out very quickly but they actually make the rear wheel rear slow down, even lock it if ya want to without standing up on the brake lever!
about £12 - 14 a set
Ray.
Old 11-Oct-2006, 11:21   #5
I'm not sure of the spec's but apparently you can use the 'prillia RSV rear caliper and master cylinder. Both use bigger piston sizes. I'd guess the rear caliper is a 34mm (ST?) rather than 32mm and the master up to 13mm from 11mm??
The discs and caliper on the RS monster are also bigger so maybe a parts bin raid could sort it? You'd need the RS carrier to though.
The pad option Ray mentioned maybe worth a look at to, along with maybe a wavey type disc?
Old 11-Oct-2006, 21:09   #6
Thanks for the info, will look into pads then will check out what calipers will fit.
Cheers Chris.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:46.
