Old 17-Oct-2006, 16:06   #1
couchcommando's Avatar
Mood: ooooh
Running a 620 engine on carbs ?
Anyone know enough to comment as to whether a 620 motor could be made to run without the injection set up ? Carbs would obviously work but is the 620 ignition linked to the fuel injection ?
Old 17-Oct-2006, 16:33   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
I don't know the answer, but for the sake of discussion...
Even if the ignition is linked to the injection i don't see why that would be an issue. The ecu would send a signal to the injectors, whether or not the injectors are there won't be fed back to the ecu would it?
Old 17-Oct-2006, 16:43   #3
ali ali is offline
ali's Avatar
Mood: Damp
I've spoken to at least one respected tuner that reckoned a well set up pair of FRC39s would do a better job than the injectors. They're not easy beasts to get set up though... and god knows what you'd need to do with the electrics!
Good luck.
Old 17-Oct-2006, 16:50   #4
Mood: ooooh
Thing is if you have the 583 bike and a 620 engine but non of the associated 620 electrics what do you do ?
Fuelling is easy with a pair of carbs which leaves ignition, I suppose you could use the 583 pick ups and 583 ignition ? Another consideration would be an early injected 900 system as that doesn't have the costly immobiliser in it ? Things I say I'll do for people !
Old 17-Oct-2006, 17:58   #5
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Doesn't have to be an early injected 900 either. I have a 2002 900ss as my road bike. It's the last of the 900ss bikes, before Ducati went up to the 1000ss. I have no red key or inbuilt immobiliser. I needed to fit a Datatool alarm/immobiliser for that level of safety! On the other hand if I lose all my keys I'm not totally screwed either...........
My older 1999 750ss, one of the first injected models, also didn't have the built in immobiliser, but I think there was something tricky about the ECU being one solid unit. You couldn't fit a new chip to it to change mapping etc. Nelly knows a lot more about this than me......
Old 17-Oct-2006, 18:34   #6
DSC Member AK AK is offline
AK's Avatar
ask rich at louigi moto as this is what he did for the latter part of last year for the bike that dom rode
Luckily rich realised his error and the bike had the carbed heads removed and it now flies for hawk
Old 18-Oct-2006, 00:26   #7
domski's Avatar
It's great if you want about 40bhp.
Old 18-Oct-2006, 08:37   #8
Mood: ooooh
Why would fuel injection give more hp ? I'm assuming more was changed than just the injection for carbs ?
I guess project abandoned lol
Old 18-Oct-2006, 08:43   #9
AK's Avatar
tony there is quite a but of difference in the carbs for the ie bikes to the carbed bikes internal angles porting etc
am happy to chat about it if you want to call me later today mate
Old 18-Oct-2006, 08:50   #10
Mood: ooooh
Yeh cheers Alan, can you mail me your number over ? ta
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:42.
