Old 20-Oct-2006, 20:48   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
oil pressure switch
Hello
Can anybody help.
A. is off my bike, will B fit?
TopiToo
Old 20-Oct-2006, 20:55   #2
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
no it won't
Old 20-Oct-2006, 21:09   #3
Bikes: 748ish . .
Hello chass
thanks, as I thought, found the new one in the garage
was hoping I could use it.
TopiToo
Old 20-Oct-2006, 21:29   #4
I would have said yes as I removed the later type from my 620 engine after it leaked at the Cadwell trackday and fitted the earlier one with the spade connector.
I modified the harness bypearing off soe of the insulation on the original connecting wire and Ting in a piec of wire fitted with a 1/4" spade terminal.
It worked fie at the final DD round
Old 20-Oct-2006, 21:35   #5
Bikes: 916 Strada
Chaz's Avatar
Ones a taper thred i't not the right sensor IMO.
Old 20-Oct-2006, 22:12   #6
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
I believe the pressure switch off a Vauxhall Aguila (sp?) 1.1 is pretty much identical and a straight swap, costs a couple of pounds from your local car parts place.
Old 21-Oct-2006, 05:52   #7
I think I've got a spare one somewhere,....brand new,still in the packet.
No use to me.
Old 21-Oct-2006, 10:00   #8
bolds bolds is offline
Yes it will fit-as Ducati supply the later type one now as a replacement for the earlier type as a kit with a new connector in with the switch
Pt no 69921511A
Old 21-Oct-2006, 13:07   #9
Bolds is right. The early type has been superceded and type B is now supplied with a new connector you need to fit to the existing wire.
Old 21-Oct-2006, 22:38   #10
Mr.R Mr.R is offline
Mr.R's Avatar
Hi, I believe VW oil pressure switches fit, but when the red light shows your OK when it doesn't, your in the ****, as in reverse. However by the time your oil light warns you it's to late anyway,as in it's time for a rebuild! Which ever switch you fit! I might be wrong,but i think the only thing the oil pressure light can warn you about, is a failing oilpump(or drive to it) or worn Bigend shells, either way the motor will have to be stripped. If you carry on rideing the motor will start to "knock" shortly followed by a rod popping out to say hello.........GAME OVER!......The works racers have no switch fitted because they are rebuilt after every race, I think the oil light is an idiot light to stop the average owner from throughing a rod and thus totalling the motor.
Steve Robins S.W.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:02.
