Old 21-Oct-2006, 19:07   #1
weeksyracing weeksyracing is offline
Vented clutch cover, do you keep the rubber spacer/gasket ?
Just wondering as i think it would 'look' better without the rubber....
Thoughts ?
Old 21-Oct-2006, 19:16   #2
doogalman's Avatar
No. just put some spacers behind if there is not enough clearance .
Old 21-Oct-2006, 19:21   #3
Albie Albie is offline
Albie's Avatar
no not on mine. Not even washers
Old 21-Oct-2006, 19:30   #4
keefer keefer is offline
keefer's Avatar
never used a rubber
Old 21-Oct-2006, 20:19   #5
Mr.R Mr.R is offline
Mr.R's Avatar
No....No....No....Have i made myself clear? The gasket is there as a silencer,to take some of the clatter away! Open clutch.. rubber gasket= waste of space!
Steve
Old 21-Oct-2006, 21:17   #6
Cheers gents. Going to order up a new set of springs and also a few other bits, got some exhaust stripping and cleaning to do first and will then crack on with it.
Old 21-Oct-2006, 22:46   #7
Its not just a gasket though, its got spacers built into it. Depending on the type of pressure plate and cover you are running you may find that there are clearance issues. Certainly with the standard set up the springs will it the cover if you don't use spacers.
Old 22-Oct-2006, 18:20   #8
peter grover peter grover is offline
i have a ducati vented carbon clutch cover on my 916.i have used the rubber gasket and cut away the portion by the cut away part. without the gasket the clutch springs foul the cover.useing the gasket looked neater than packing it out with washers.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:00.
