Old 25-May-2003, 21:23   #1
Phil Butler Phil Butler is offline
Bikes: ST2, 750ss, 350 Forza, W650, CB250RS, 5x Royal Enfields
Mood: Nesun Dorma
LCD display
I have a problem with the LCD display, it goes through it's check routine and then the fuel read out shows empty ( 1 bar flashing) the fuel light also stays on. The fuel tank is full, I charged the battery yesterday refitted it to the bike and this problem has arisen, Any help or ideas gratefully recieved.
Cheers, Phil
Old 27-May-2003, 10:31   #2
Aotearoa Aotearoa is offline
Mood: Xstatic
...never had this problem ..but I would check the connections under the tank ....if the LCD was fault I would think all of the readings would be gone or faulty ...so ii would say either you've accidentally unplugged the sensor or its been pulled loose when you had the tank up .
As i said its all just guesses but hope it helps
Old 27-May-2003, 11:35   #3
Monty's Avatar
Hey Aotearoa, I like your Avatar, a bat barf grey ST4S with red wheels-did you do it yourself??
John
Old 27-May-2003, 17:00   #4
I reckon Ive seen that before,......on the American Speedzilla board?
Old 28-May-2003, 17:35   #5
Did you get the pannier fitting instructions that i took the trouble to scan and email to you?
Paul.
Old 10-Jun-2003, 12:59   #6
Mood: Xstatic
nope not mine ... i found it on a web site http://www.ducatisuite.com/gallery.html ...sorry for the delayed reply ... been in Sweden with the wife redecorating her batch / cottage ...am dam glad to be back at work for a holiday!...hardest 10 days i have worked in years!...i got conned into thinking it was going to be relaxing ...little did i now it stays light untill 11 pm !
Old 10-Jun-2003, 15:04   #7
saj288 saj288 is offline
Hi guys, saw the note referring to the pannier fitting instructions - thought you might be interested in the mod done to my bike - prior to me owning it.
http://www.onewest.net/~ckirk/Bikes/...ignal_mods.htm
in brief they have shortened the pannier brackets and done a mod to the indicators - enables the brackets to be removed in 10 mins without re-wiring the indicators each time.
SA
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:46.
