Old 06-Nov-2006, 19:24   #1
9rrr 9rrr is offline
Talking Brake switch
Think I am going to go for the upgraded BREMBO brake and Clutch master cyliders for my 996r, but have been told that the original brake switch wont go into the upgraded Brembo MASTER CYLINDER UNIT. The supplier says they would supply a banjo type switch which you attach to the master cylinder. The banjo senses the difference in pressure when you apply the brake which activates the brake light.
Question. Im CRXP at diy, is this an EASY job to be tackled. HAS ANYONE GOT A PHOTO OF THE UPGRADED BRAKE MASTER CYLINDER WITH THIS BANJO ATTACHED. Thanks Ian
Old 06-Nov-2006, 19:47   #2
Lily Lily is offline
Mood: stiff and tired
I can take a picture and post it but it won't be for another couple of weeks as Bike is off to Spain
Old 06-Nov-2006, 19:49   #3
keefer keefer is offline
keefer's Avatar
its very very easy
you wont have a problem
Old 06-Nov-2006, 20:07   #4
brake switch
Lily that would be great if you would do that. Keefer I admire your trust
Old 06-Nov-2006, 20:16   #5
keefer's Avatar
Stevie Wonder could do it
you will be fine
Old 06-Nov-2006, 20:41   #6
brake switch
Top man. Thanks very much. Incidentally. Could you see an improvement over the standard brake set up ?.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:00.
