Old 07-Nov-2006, 00:54   #1
gunforhire gunforhire is offline
gunforhire's Avatar
Mood: #73 Class A newbie: I'm fitting seatbelts!
Question Slipper clutch noise on Up shift
I've got a Ducati Corse slipper clutch fitted to a 1998 748 I've just bought.
I had a 2001 748 before.
Thing is there is a 'grinding' coming from the clutch when I pull away from the lights. i.e. let the clutch out slowly from a stand still.
When it's going it's fine. No problems on downshift.
It's been recently serviced, has race plates, and springs x 4.
Any ideas?
Cheers in advance
Old 07-Nov-2006, 09:56   #2
Ray Ray is offline
Ray's Avatar
Par for the course (sorry) is it a bit "grabby" on take off as well??
Sometimes a good clean out of the build up of dust helps, a worn basket doesn't help either.
All helps to maintain the racer image as ya kangaroo away from the lights in a blitz of noise.
Ray
Old 07-Nov-2006, 14:21   #3
ducv2 ducv2 is offline
Always found mine to be grabby and noisy when I'm gentle with it. If you set off hard then its OK. Like Ray says, par for the course (on a Duke anyway)
Old 07-Nov-2006, 23:15   #4
gunforhire's Avatar
Grabby! That's the word!
The 748E I had was great but it had a standard clutch.
So this is the delight of a slipper clutch?
I'd hate to try and get off the line in a race with it
Old 08-Nov-2006, 02:16   #5
Carbon749's Avatar
Mood: I own a flame thrower
Had the same problem with my 749r slipper. Get it stripped, cleaned, ramps greased and pack height set. Will then feel like a "standard" ducati dry clutch.
Cost me an hours labour to get mine done and the bike was transformed.
Old 08-Nov-2006, 07:23   #6
I agree with Carbon, I had the same problem as you, grated as you pulled away, worse when two's up. Took it to Neil at Cornerspeed, he stripped it, changed a couple of the steel plates & she has never made a noise since, top man.
Old 08-Nov-2006, 09:33   #7
Ian Harris Ian Harris is offline
Ian Harris's Avatar
If its one of the ones with balls and ramps, its a good idea to keep a very close eye on plate wear. I had one of the Ducati Corse ones, and let the plates wear down a bit to much before having it serviced....started off a bit graunchy, ended up very graunchy because the balls escaped out of the top of the ramps and wreaked carnage in the basket. I've now got a very nice Ducati Corse paperweight
Old 09-Nov-2006, 10:29   #8
gunforhire's Avatar
Supposedly all that was done by Ray at Rosso Corse a few weeks ago
Will give him a call this afternoon
Old 09-Nov-2006, 10:40   #9
keefer keefer is offline
keefer's Avatar
I wouldn't worry to much
mine does it even when it has been striped and cleaned
unlike others I find it better if you feed it in gently
horses for courses I suppose
if you really want to be sure do it yourself
strip it down and clean all the plates with brake cleaner
re grease the ramps and see how it feels
they are not that hard to work on
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:59.
