Old 07-Nov-2006, 16:21   #1
Little things mean a lot
One of the things that I hated about my 888 was the "Superbike" disgust-o-grips that it came with and the cheap white nylon end caps on the bars.
Well, after some medium compound diamond pattern Renthal grips turned up today (thanks B&C Express) to go with the DP bar ends that turned up yesterday (thanks nattyboy), I managed to take 20 minutes out of a really busy day to fit them onto the bike.
I had read that the grips could be a bit of a faff to put on. I was already aware that the throttle side was a bigger diameter than the clutch side to cater for the throttle tube (thanks to a frustrating episode with a trials bike when I got it wrong) and I read through Nattyboys thread on how to put them on. General advice was to heat them with a hot air gun to make them pliable and various lubricants were suggested - the favourite being plain water. So, being an all round smarta*** I put the heat and water theories together and popped them both in a pyrex jug of boiling water for a few minutes. I wiped the bare bar and throttle tube down with a water soaked rag (cold water) and they slid on a treat.
I had my right hand riding glove on to help hold onto the grip and twist it on without taking the skin of my hand, but I found that if you sort of hammered it on by sliding your hand along the grip and hammering the raised bit at the end it popped them on with no fuss whatsoever (but then I've had a fair amount of practise at that particular motion )
A few minutes later and the bar ends had joined their new friends and the T8 has taken another tiny step closer to how I want it to be.
Only a little thing but still cool
___________^
Old 07-Nov-2006, 16:37   #2
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
As they say Jools its the little thing's in life that makes the differance as I found out when I drop one lickle tooth from the front sprockett,don't suppose we will see much of the T8 now the weather's closing in for Winter. At least the ST will be a bit quiter 4D
Old 07-Nov-2006, 18:12   #3
851neil 851neil is offline
Mood: need a bike...
Cracking tip with grips is GT85, it's a lubricant I use on push bike chains and the like - but believe me there's no way you can budge those grips.
Have used this stuff for years and never had a grip slide off or twist around the bars.
Old 07-Nov-2006, 18:14   #4
oh yeah spray the bars and the grip liberally and just slide on, 5 minutes and they won't move. When you come to remove them, or if you havn't sprayed enough and they stick halfway on, just slide a thin screwdriver up the grip and spray in the GT85 and off the grips pop easy as you like.
Old 07-Nov-2006, 18:18   #5
jeff st4s jeff st4s is offline
jeff st4s's Avatar
Mood: Looking for a one way ticket to the 'Ring.
Have to say I agree, use GT85 on my mountain bike grips and works every time.
In the past have used ladies hairspray to fix and GT85 to remove them.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:03.
