Old 10-Nov-2006, 12:55   #1
Big Duke 6 Big Duke 6 is offline
"Cloudy" front fender
The front carbon fender on my 888 needs re-finishing as it's gone white in patches..if I rub it down a bit and re-laquer will it come up any good, or should I just source a newer one? or get it painted red?
Thanks in advance
Old 10-Nov-2006, 13:18   #2
Its the effect of UV light breaking down the resin that causes the milky effect.
You should be able to (carefully!) sand it out and then apply some clear coat to build up a shine again.
Old 10-Nov-2006, 16:52   #3
DaveB916
Try some black boot polish, was a tip from a mate and worked for me.
Bit of elbow grease and it looks good again.
Old 10-Nov-2006, 17:04   #4
keefer keefer is offline
keefer's Avatar
don't think the boot polish idea will last
but have a go if you want
meanwhile sand it down with wet and dry and get it lacquered.
works a trick
my air ducts went the same.
they look blingin now though
Old 12-Nov-2006, 15:41   #5
Cheers for the advice, think I'll try the lacquer route.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:20.
