Old 12-Nov-2006, 10:58   #1
stephen hall's Avatar
Wink argument
please can i have your opinion as to the following .....whilst at work last week i got into a heated discusion over what you would expect to find when draining the oil......yep i found it hard to understand as well.... here are the examples given..... nowt but oil or your lump is goner go bang, small pieces of swarf. small pieces of gasket material, thread swarf, smurfs ...no actualy i made that up....but the discusion got almost to blows between a harley rider and in his opinion a..... plastic rocket rider,, made me think to have a real good look next time i change
Old 12-Nov-2006, 11:01   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Your opinion is about right.
Old 12-Nov-2006, 11:34   #3
Question imo
i think very small pieces of mentioned would be o.k. its when there is a lot and it gets bigger its time to worry ...am i wrong????
Old 12-Nov-2006, 11:39   #4
Yes. Although it's often quoted that if you spot lots of bright silvery shards or shavings in the oil strainer then you may be suffering from the infamous rockers problem. It's quite normal in my experience to get small amount of debris in the strainer or on the magnet with almost any bike over time.
Old 12-Nov-2006, 11:44   #5
There's a good reason why there's a magnet fitted to the drain plug.
Old 12-Nov-2006, 11:46   #6
Indeed. SO you can hang it on the garage door when changing the oil
Old 12-Nov-2006, 12:55   #7
swannymere's Avatar
Mood: High as a kite!
I did'nt think you needed a reason to slap a Hardley Ableson rider
Old 12-Nov-2006, 14:51   #8
DEMON DEMON is offline
DEMON's Avatar
Mood: on the back wheel !!
You may find also :-
water deposits (from condensation, or internal leak,ie head gasket)
White metal from your main bearings
silica deposits...from sand left in the castings of the crankcases
Carbon deposits...from the products of combustion (blow by)
Sulphuric acid formed through the combination of carbon deposits and the water (although very small amounts)
Varnish like deposits from oxidised oils
Plus a load of toher constituents !!
Old 12-Nov-2006, 15:21   #9
baylissboy baylissboy is offline
baylissboy's Avatar
Mood: Happy as Larry!!!
Blimey, i only get oil!!
Old 12-Nov-2006, 17:18   #10
I've never yet owned a car or bike that hasn't left bits of swarf on the sump plug at every oil change.
