Old 12-Nov-2006, 20:27   #1
9rrr 9rrr is offline
Question How to clean radiator.
Just a quickie. Just taken my radiator off, covered in crud. How do you lot clean the bloody thing. Thanks
Old 12-Nov-2006, 20:30   #2
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello 999r
pressure hose and twisers to straighten the fins
TopiToo
Old 12-Nov-2006, 20:31   #3
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Toothbrush and Muc-off or similar.
Old 12-Nov-2006, 21:27   #4
crm250 crm250 is offline
crm250's Avatar
Mood: Firing on all 4 !!
Be very carefull using a pressure washer as you will bend all the fins with the blast.
I have a few NC/RC30's and these are the pits to keep clean on the lower rad, anyway what i do is simply remove the rads, leave to soak for a few days in a bucket of water, then using a small cable tie proceed to poke the worst of the mud out and straighten any bent fins, then when the mrs isnt looking throw it in the dishwasher, and give it a couple of cycles turning it over each time. then enjoy your new spankly clean radiator.
Old 12-Nov-2006, 21:47   #5
Bikes: 748ish . .
Hello crm250
good point, take it easy if you use a pressure washer
dont want to damage the fins in anyway
regards
TopiToo
Old 12-Nov-2006, 22:12   #6
keefer keefer is offline
keefer's Avatar
soak it in a big sink of water
and washing up liquid
then gently clean it with a tooth brush.
Don't use a pressure washer you will bend the fins
go careful
Old 18-Nov-2006, 20:11   #7
Mr.R Mr.R is offline
Mr.R's Avatar
Hi, MOTHERS dish washer, i wish i'd thought of that, i used to boil my chains i n greese on her hob, bake on my paint in her oven....but never thought of the dish washer......hold up i was her dishwasher.
steve
