Old 20-Nov-2006, 10:38   #1
Big Duke 6 Big Duke 6 is offline
Bike conked out
My 888 strada has conked out twice and won't start until I clean the spark plugs, the electrodes are black. I put the original cans back on 2 weeks ago, replacing the carbons and it has been unreliable since. I check the original bill of sale and it says under optional extras "hi level cans and chip". Does that mean it really won't run very well with the standard exhaust if it has an upgraded chip? Thanks for any suggestions.
Old 20-Nov-2006, 10:44   #2
Martinp Martinp is offline
Martinp's Avatar
Mood: 748ish
Originally Posted by Big Duke 6
Does that mean it really won't run very well with the standard exhaust if it has an upgraded chip? .
Correct, The reason your plugs are black are because the engine is running to rich. Which is down to the fuelling so you need to change the chip.
Old 20-Nov-2006, 23:27   #3
Douglas851 Douglas851 is offline
Have you tried putting the carbons back on? I am surprised that putting the original cans on makes that much difference. How old are the plugs and are they the correct grade?
I have found that using standard cans with a upgraded chip, FIM in my case, creates no running problems at all.
Old 28-Jan-2007, 13:56   #4
I have switched back to the NGK plugs and fitted a new regulator, when I took out the old ones they were as black as a black thing on the electrode bit. Does that mean it's running too rich?
Old 28-Jan-2007, 14:26   #5
weeveetwin's Avatar
Yep! Check the air filter as well as the fuelling chip - if it's blocked (dirty) the fueling will be starved of air and therefore too rich (in neat fuel).
Old 05-Feb-2007, 12:26   #6
Changed the regulator, air filter ok, changed plugs....still no good, bike at duke doctors in Sevenoaks as I am also losing brake fluid on the clutch side, bloke said some seal has gone, as it's placed where all the road crud hits it..never mind
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:21.
