Old 28-Nov-2006, 07:45   #1
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Angry ipod geek needed
my ipod is in need of re formating because it keeps eroring but will not conect to any of the computers in the house does anyone have any fixis for this
thanks Alec son of Chass
Old 28-Nov-2006, 07:55   #2
Herb Herb is offline
Its easy to reset and I have done this when the click wheel started to play up.
Plug the ipod into a power supply and connect to a wall socket. Not the computer. Turn the hold switch to on and back to off. Press and hold down the play and menu buttons together until the apple logo comes up. This should reset without losing your music.
Why can't you connect to your PC? Can you not connect to itunes?
Old 28-Nov-2006, 08:05   #3
Bikes: 916 Strada
Chaz's Avatar
Thank's but I have alread tried that!
No it won't connect to itunes.
Old 28-Nov-2006, 08:49   #4
khushy khushy is offline
khushy's Avatar
My iPod Nano was defunct when I bought it 2 months ago . . .
Since then Apple have released some new software for it which makes it work properly now - no probs.
Plus Apple service is excellent.
The only other problem I have had with it was that the headphone socket came loose - I now have a brand new iPod c/o Apple!
Khushy
Try iTunes and then download the latest firmware for your iPod - reset it - connect it and wipe it clean installig the new software - other than that call Apple Direct - 0870 876 0753 - they will sort you out.
Old 28-Nov-2006, 09:29   #5
if it won't connect them something isn't right for one matey, does your ipod appear in device manager when you connect it to your PC?You could try downloading the latest Apple (iPod) updater from Apple this may or may not help but not until you can connect anyway.
Old 28-Nov-2006, 21:44   #6
djb djb is offline
djb's Avatar
There is a complete reset configuration wich I've used before but it does delete everything. Let me know and I'll try and remember it....
Could also try deleting profiles and reregistering but not sure this will do the trick.
Old 29-Nov-2006, 09:39   #7
Its either the drive cable has got dislodged (quite common) or that the disk itself has failed.
Nothing to lose now except to open it up and try reseating the drive connections: http://www.ifixit.com/Guide/iPod/
If that doesn't work then its new disk time - a good chance to pay a bit extra and put a larger drive in there while you're at it. Avoid ebay though - buy from a reputable dealer who has a no quibble guarantee / returns policy.
hth.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:45.
