Old 27-Apr-2015, 22:19   #1
ribeye998 ribeye998 is offline
998 bip - new clutch and ECU
Can anyone advise on what I might have to pay to replace the clutch on my 25,000 mile 998? Also can anyone give me a part number for an ECU for the 45mm termi's that I have fitted - there dont seem many around on e bay?
Old 28-Apr-2015, 21:58   #2
I have the ECU part number as 96507402B
As for clutch price that depends on how much you are replacing
Friction Plates
Drive Plates
Outer Basket
Inner hub
Old 28-Apr-2015, 22:55   #3
Thanks for the part no - thats for 45mm pipes?
Its for replacement of the lot!
Old 29-Apr-2015, 00:04   #4
28640341A is Standard
96507402B is DP 45mm
96507502B is DP 50mm
if you want one new... £960+VAT!
Old 29-Apr-2015, 10:03   #5
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Any IAW59M ECU can be made into the DP ECU you require. They don't crop up often on eBay though. Antonye may be able to help you out.
As for clutch plates, I have been buying from this eBay seller
http://www.ebay.co.uk/itm/NEWFREN-F-...em3cda d08100
He sells kits with the metal plates as well.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:24.
